Tom's Hardware > Forum > Smartphones & PDAs > Handhelds General > Blackberry PIN entry problem
Forum Smartphones & PDAs : Handhelds General - Blackberry PIN entry problem
Archived from groups: comp.sys.handhelds (More info?)
Hi, I've got a Blackberry 7230 device and I'm having a problem entering the
PIN number into it.
My PIN has 4 numbers and 4 letters. I can enter the 4 numbers OK but when I
try and enter the characters A + B out of the PIN, no character is displayed
when I press the keys. It's almost as if only the number keys are active on
the PIN entry screen.
Apologies if I'm being stupid but the PIN is all 8 alpha-numeric characters?
I should be able to enter any character OK?
Many thanks,
David
Sponsored Links
Hi David,
The Blackberry actually has two "PIN" codes, one is 8 digits
(alphanumeric), the other one, that you should use, is only 4 numbers.
You should have received it from your service provider.
Well I hope this is all relevant to you, things might differ from one
provider to another.
Good luck,
SD
"David Martin" <david@heathen.plus.com> wrote in message news:<41914c8f$0$24079$ed2e19e4@ptn-nntp-reader04.plus.net>...
> PIN number into it.
> Many thanks,
> David
Reply to Anonymous
There are 1093 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
