Im a complete noob at water cooling i'v only read a few posts about it. I'v got a Copper Car Radiator and Heater Core from my dads old car he is throwing away. Is it a good idea to use the Car Radiator? I dont mind the size.
Also im thinking of using both. I want to put the radiator a few meters away from the PC and the heater Core on the case and fans only on the Heater Core. Is it a good idea to use both or there is no point in doing this?
What im thinking is because my Car Radiator is at some distance from the PC water will heat in the tubes going to the PC so a heater core at the PC will cool it too.
Will be Cooling CPU, NB and GPU.
Loop: Pump>Car Rad>Heater Core>CPU>NB>GPU>Pump
Some AC Pump i dont know how powerful pump to get? What specs?
I nearly peed myself laughing when I 1st read the post but then got thinking maybe it's not a bad way to go. I don't think it would look nice at all and you would have a bit of a problem moving the PC about but the cooling potential would be awsome.
Just use the cars water pump and cooling fan to complete the build and you're good to go. Vrooom
And how exactly is he supposed to use the car's waterpump? Those aren't electric you know, they're belt-driven. Well, I guess he could use it, he'll just need to rig a bicycle up and pedal as hard as possible the whole time he's using the computer.
OP: The heater core is fine, don't bother with the radiator. The radiator is simply to large, you would need a pretty massive (and expensive!) pump to maintain good positive pressure throughout your system. Many WC setups use heatercores instead of specialty radiators. Just make sure you flush it very well before use as it likely has an accumulation of gunk inside. Also, if it has copper tubing, make sure you keep a close eye on your component selection and avoid anything made of Al, otherwise you'll have a ton of contaminants floating around in your coolant.
Using both the car radiator and the heater core would be major overkill. Look for a shop that can braze a smaller inlet and outlet onto the radiator and then use 1/2 inch lines between the radiator and the pump and so forth. Just use a large capcity pump from Danger Den or Swift Tech. I've seen a number of people use small car radiators successfully. Depending on the size of the radiator, you can use anywhere from two to four fans for cooling, from 120 to 250 mm size.
Do not think of using a car water pump, as the pressure would be way too high for the rest of the system. Other than that, your idea is not so crazy, as its been done by many people in the past.
YEAH OVERKILL i like. Seriously using both just sounds cool to me. Was wondering if it would actually work.
Quote :
Dunno anything about car pumps... but i think the fan is belt driven too
Is the Swiftech MCP655 gonna be enough for this thing? I would prefer an AC pump so i can just plug in the wall
If you can set up the heater core in a box and use long enough hoses you could use it to heat the house in the winter. The tough part will be the water pump and where to put it and then power it.
Maybe you can pick up one of those small AC window units and have some tubes come off of that to cool the cpu that way you can cool the cpu the same time your cooling the house.
Then switch over to the heater core in the winter.
Seen a few discussions, sounds like the A/C radiators are often the best for surface area versus size and weight. Import models can be 12x18 or less and only weigh a couple of pounds empty.
Most modern cars have electric-driven radiator fans for reduce parasitic loss on the engine. A 655 won't be anywhere near enough, keep in mind that given that most radiators have large collection tanks on the top and bottom, and then the amount of tubing they have, there will be a huge pressure drop, much more than a normal WC pump can handle. The heater core is a much more reasonable idea, or even an oil cooler from a heavy duty truck or a turbocharged car.
however, if you feel like the flow isn't adequate, then you'll really need to up the ante and think about pond-water kind of pumps, which some enthusiasts do.
