Closed Solved
Power dvd11 ultra
OK i bought the Power dvd11 ultra like ya said do, I loaded it and did the update. But I still cannot view any blueray disc! What am I doing wrong? Is there some kinda magic little device I need? This is really frustrating, need a little help here.....Thanks, Edwin J
MY system:
1 x G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model F3-10600CL8D-4GBHK
1 x SAPPHIRE 100314SR Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
1 x Creative Sound Blaster Audigy SE 7.1 Channels
x LIAN LI ARMORSUIT PC-P50R Red Aluminum ATX Mid Tower Computer Case
1 x SAMSUNG Black Blu-ray Combo SATA Model SH-B123
1 x CORSAIR CWCH50-1 High Performance CPU Cooler
1 x Intel Core i7-870 Lynnfield 2.93GHz LGA 1156 95W Quad-Core Processor BX80605I7870
1 x EVGA P55 SLI 132-LF-E655-KR LGA1156 Intel P55 ATX Intel Motherboard
1 x COOLER MASTER Silent Pro M600 RS-600-AMBA-D3 600W ATX12V V2.3 SLI Certified CrossFire Ready 80 PLUS Bronze Certified Modular Active PFC Power Supply
1 x Microsoft Windows 7 Home Premium SP1 64-bit - OEM
1 x Western Digital VelociRaptor WD1500HLFS 150GB 10000 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
13 answers Last reply Best Answer
More about power dvd11 ultra
  1. What do you use for a monitor?
    Do you use dvi or HDMI?
    Is your monitor HDCP compliant also?
    [:briovaz:3]
  2. Thank you master, I'll be a radio shack in the am to get that funny looking little HDMI cable that promptly fits to my monitor and the card.....I'm learning!!
  3. right now it has the larger dvi ends
  4. How is the issue with powerdvd coming along?
    [:briovaz:3]
  5. no, I pluged in the cable to both ends and i got a black screen???
  6. i switched to this monitor from newegg: 1 x Asus VE228H 21.5" Full HD HDMI LED BackLight LCD Monitor w/Speakers
  7. Best answer
    Keep me updated!
  8. I'm baffled, I think i'll take the computer and this AsusHDMI monitor to the local guru's computer shop......
  9. Any luck getting it running?
  10. Power dvd11 ultra is running great, Thank you for the advice. However, I didn't have to even use the hdmi cable cable i bought at radio shack, it works on the dvi cable
  11. Best answer selected by Edwin Johnson.
  12. Awesome,glad it is solved!
  13. This topic has been closed by Area51reopened
Multimedia Apps
