Yes No
Ads
Tom's Hardware > Forum > Windows Vista > Security > Trojan problem
Trojan problem
Forum Windows Vista : Security Trojan problem
Was browsing the web... then some pop under ad appeared.
Pop under was trying to open Adobe Acrobat for some reason, was like WTF and terminated the process (I have BlackICE defender application protection, it automatically alerts you when an unknown app. tries to run).
Then a file called unwise_.exe tries to open itself, located in the c:\windows\fonts folder. WTF again, terminated it.
Forgot about it for a few hours, then BlackICE firewall started going off like crazy. Checked Task Manager, and noticed several instances of cmd.exe and ftp.exe running.
Crap... somehow got a trojan. The thing is, I dont run any executable files from "shady" sources, just download some PDF files at most. So it was probably a vulnerability in Acrobat or FireFox that allowed the trojan to install.
sombody tell me wat to do???
Reply to Anonymous
Try downloading Malwarebytes and running a full scan. Usually it will take out any such instances of malware.
------------------------------ -Kevin
Can you access TH on your smart phone?
Reply to buwish
Adobe Acrobat recently had some nasty security flaws. You probably hit a site where they redirected you to a page to exploit the Reader.
Reply to kewlx25
Delete all that rubbish if you can, it sounds way too dodgy
Download, install then run malwarebytes, preferably in safe mode
Reply to ricky_critic
There are 2001 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I cannot get my external hard drive fully installed on vista
By nhasian, 1 day ago:
rather than fdisk it is recommended to use Disk Management. Create and format a hard...
Best offers
Top experts
