AC-3 Sound Receiver
I have a pansat satellite receiver and on some channels it will not pick up AC-3, S/Pdif sound. Is there an adapter that I can attach to the pansat to receiver this sound?
1 answer Last reply
More about sound receiver
  1. The audio decoding is done inside the receiver, you should check with the vendor to see what the issue may be. Especially since this only happens on some channels. That means the actual audio processing is working.
