I’m planning on building a system with an ASUS Striker Extreme, a Q6600, and running Vista 64bit. I want 2x2GB, and have been looking at the following…
Which might be better, and should any of these have a better chance of working with that motherboard, as none of them are on the QVL for that board.
From the list above, I was thinking the Patriot eXtrame for 199.99, or the G.Skill for 209.99
I was also considering spending a little more and getting 4x1GB at DDR2 1066, but I saw quite a few threads about people having problems with 4 pieces. Plus I would like the ability to add more ram later if needed.
Those kits are the best two, and you're correct with what you say above, the 2 x 2GB would be better for the reasons you have stated, if you want 4GB that is
