Yes No
Ads
atikmdag problem
Forum Graphics & Displays : Graphics Cards atikmdag problem
Hello!
Does anybody have any idea as to why I am getting the atikmdag failure notices in Vista?
It seems to appear when running FSX. No problem for about 4 days (since I got this machine up and running) but it is happening now. Screen freezes, then blacks out then comes back with the little error window at the bottom right stating that atikmdag stopped responding and that Windows has recovered.
Asus P5K-E WiFi mobo
Intel E6600 (not overclocked)
Sapphire Radeon 2900XT
2GB Corsair DDR2-800
Windows Vista Home Premium
FSX Deluxe
Cheers!
Reply to ouzopwr
Yes, I am...but I just uninstalled them and trying 7.4 and then 7.5 to see what crops up.
Reply to ouzopwr
- 0 +
Well...
tried both 7.4 and 7.5 but no joy. Reverted back to 7.6 and now I'm getting corruption (very thin broken horizontal lines) all over the screen. Upon rebooting they seem to disappear but then simply by opening any program they re-appear. Monitor is a new Samsung 971p.
This is very frustrating.
Reply to ouzopwr
- 0 +
Latest update:
Uninstalled 7.6: No artifacts or screen corruption. (Of course, no 3D capabilities either)
Re-installed 7.6: Artifacts and corruption are back with a vengeance.
I've been an ATI guy for a long, long time but it seems that AMD has really screwed the pooch on this one. I'm seriously thinking of removing Vista and using XP until ATI straightens out their act and gets some decent Vista drivers to the market although I'm really not too sure how XP would behave like under 7.6 or even 7.4 for that matter. Any suggestions?
Looks like the bean counters put too much pressure on the tech dept. and they pushed the 2900XT out the window too darn fast. The hardware seems ok but the drivers look like they could do with some serious re-writing.
Just my 2-cents worth.
Reply to ouzopwr
- 0 +
Ooo-kay...
this IS interesting. Uninstalled Vista and stuck trusty ol' XP in drive C:
Installed all drivers (mobo, soundcard, etc etc) and then fired up the Catalysts. Re-boot and...lo and behold...screen corruption yet again! This happened with both the 7.4 and 7.6 versions.
Could it be the hardware? 8O
Reply to ouzopwr
Well I had a variety of atikmdag errors. I tried all the suggested solutions, from arcane settings changes (like sys config utility/boot tab/advanced/etc . . .), to a variety of driver changes (catalyst, windows default, etc.), to stripping down the PC to a hard drive and a DVD, reloading Vista, and adding hardware back one component at a time.
One reference I did find which struck me as curious was someone that wrote that when they had taken their RAM down to one 1GB chip things ran fine. That stayed in the back of mind.
As I added back cards, drives and peripherals everything was working perfectly. Vista is/was insanely stable. Felt stable, no issues, nothing.
In stripped down mode I had been running one stick of memory. I didn't figure it was a RAM issue because I had run detailed tests on the RAM and everything checked out. In any case, the issue must be with one of the stick of RAM I had, because as soon as it was added back I had the error messages, the BSODs and the freezes.
In any case, hopefully I will save you a lot of time: Physically check your RAM through trial and error. It worked for me.
Reply to stever222
I think I've found another solution to this one - it's been driving me INSANE! Brand new Dell Studio 1735 working fine and then 3 months later Atikmdag issues appear - no way it's a hardware problem as suggested by ATI and Microsoft.
So far, the following solution appears to be working:
Open up search on Vista and look for System Configuration. Run it.
Select the Boot tab and then click on Advanced Options...
Click the number of processors so the tick box is highlighted and set your processor number to whatever is on your system (mine's a dual core so I selected 2).
Click the Maximum memory check box, only this time, reduce the max memory by 1 or 2 megs. Click OK.
On the system tab, uncheck the ATI External Event Untility - you can try leaving it checked if you want but I've not noticed any detrimental effect of this not running for some strange reason!
OK everything and return to your desktop.
Now.... go to the control panel and open up the display properties. Disable the transparency on your windows, ok this and then reboot your PC.
So far everything appears stable and I've not had a single error yet. It may be just the memory reduction part but now it's working I'm not going to change anything else.
Good luck.. hope this works for you.
Graeme
Reply to catch222
I just turned up the fan speed on my HD4850... I haven't had a problem in a month. Watch your temps.
------------------------------ q6600 @ 3 Ghz
4x1 gb DDR2-800
GA-P35-DS3L rev 2.0
Sapphire HD4850 512mb
Reply to Koolaidman23
try uninstalling catalyst control center. then use rivatuner or something to control your fan. you may lose the convenience of CCC but that is a small price to pay for stability.
Reply to motokoblah
- -1 +
Did the memtest, no errors. I have a one-year old quad-core system. Quality components, very simple, very stable, good power supply, no excess heat (GPU 37 degrees C), no over-clocking, running Vista 32-bit. The motherboard is an Asus P5K-V. I do not play games. I recently upgraded to a dual-monitor system, which required more than the integrated graphics, so I got the Radeon Sapphire HD4670, another simple mid-level solution that would provide two DVI outputs at any normal resolution. (Somewhat reluctantly, remembering other ATI cards in systems and years past.) I installed the latest stable driver (8.12). Now I am experiencing _daily_ crashes with the atikmdag display driver message. This is highly frustrating. ATI support says to check hardware issues, and attempts to put the blame on any and everything else in the system. For many enthusiasts who tinker with their systems this will result in them thinking "Hmm, I must have done something wrong here." I don't buy it. In my system the only change was the ATI card, so it is the problem. Looks like the tradition of shoddy engineering, incompetent programming and poor customer service is alive and well at ATI/AMD today.
Reply to pault11
- 0 +
Didn't you post this exact same thing on a different, old thread?
Reply to Dekasav
Don't cross post multiple times in old threads, stick to current ones, or create a new one for a specific issue.
A little research into this outside of simply cut/pasting and you would know you're complaining about a symptom and not the cause.
------------------------------ Knowledge of Non-Knowledge is POWER - Fubar 2
Reply to TheGreatGrapeApe
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > atikmdag problem
There are 2001 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Graphics Card Help for a Casual
By geofelt, 2 hours ago:
As a standard, a pci-e x16 graphics card slot can deliver up to 75w to a graphics card...
Best offers
Top experts
