Screensaver problem
Forum Windows XP : Windows XP General Discussion - Screensaver problem
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I set the screensaver to automatically kick on after 5 minutes. It works
perfectly fine until I turn off the computer and restart it. The
screensaver setting does not "stick". It has to be reset every time the
computer is started up. What could cause this behavior?
Thanks
Sponsored Links
After you changed your settings to 5 minutes, did you click OK? If Yes,
that is WRONG! You must click Apply before clicking OK to
set and SAVE the settings.
Some days you're the windshield,
some days you're the bug.
> Thanks
Reply to Byte
I can hardly believe that I have stumped all you experts with my question.
Please give some thought to my problem and let me know what I can do to fix
it.
Thanks
"Derron Vandewege" <derron@cox.nospam.net> wrote in message
news:8Bfve.4244$8o.2872@fed1read03...
> Thanks
Reply to Anonymous
> my question.
> can do to fix
> it.
> Thanks
> minutes. It works
> The
> every time the
> > Thanks
I am also having the same problem. Set SS time to be 15mins. Then it
resets back to 1 min. Even occurs without turning off computer. Yes I
do apply before going OK
Posted using the http://www.windowsforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.windowsforumz.com/Basic [...] 50063.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1753666
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Screensaver problem
There are 507 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
