Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Sound Cards > Realtek HD Audio and surround sound...
Forum CPU & Components : Sound Cards Realtek HD Audio and surround sound...
I've got a C2D setup with onboard Realtek HD Audio that I'm trying to use as a home theatre pc.
I've connected the computer via Toslink from the Realtek HD to my a/v processor but am only getting stereo sound through it.
Should the digital audio not be in 7.1 or at least capable of putting out 7.1, particularly I'm wanting to get better surround sound for HD-DVD playback.
Any ideas or comments?
Thanks,
obi
Reply to obiwan05
Thanks for the reply, but if you'd read my message:
"I've connected the computer via Toslink from the Realtek HD to my a/v processor but am only getting stereo sound through it."
Toslink is the name of the optical digital output. As for the 'orange one' the EVGA board does not have an SPDIF connector on it (that I noticed anyway).
but stereo is all that is detected at the A/V processor... anyone have any idea why only stereo would be outputted on the toslink?
Thanks.
Reply to obiwan05
- 0 +
First of all did you install the 1.71 drivers?
Then, did you check the digital settings in the Realtek HD Audio mixer?
Is the speaker-setup set to 8 channel audio?
Reply to Jakc
- 0 +
I am having the same exact problem. I was wondering if you've solved your issue.
Just to clarify, I did go into the control panel and set the pulldown menu to 6 Channel sound (since I'm running a 5.1 setup).
Whenever I click the play button, I only hear the chime from the front left and front right speakers. Same for the 3D audio demo...only stereo.
I absolutely have the latest drivers, direct from Realtek's site, and I have connected my audio setup using TOSLINK.
Any thoughts??
Reply to cotif
because its over an optical toslink connection, youre limited to stereo pcm encoding (this same thing also holds true for coaxial), UNLESS the encoded format being output is something other than stereo pcm (dvds for example, typically use ac-3 encoding, aka dolby digital encoding for use over a digital connection, which allows for up to 5.1 seperate channels for the basic surround), but if you dont have that encoding, or something similar to that, then all youll get is 2 discrete channels (regardless of your systems speaker settings otherwise). a workaround for that is to have something like dolby prologic, dts:neo, or various dsp modes on your digital decoder, such as a HT receiver, to simulate surround sound to your other speakers, with only 2 front channels being received.
surround analog offers more of the same if its only 2 discrete channels, cmss and eax for example are also workarounds to getting matrixed surround with only 2 channel stereo.
another option instead of being limited to only dvds (and such) for surround playback over a digital connection, is to look for a sound card that features dolby digital live (DDL), or dts interactive/connect (DTSC). a card with either of those features will re-encode your sound (in realtime) into a compatible surround format (such as dts or ac-3), so then you can get the surround youre looking for, up to 5.1 surround by default. a sound card with an hdmi connection, will allow for hd surround up to 7.1+ channels of uncompressed pcm, but if the sound card doesnt support an hdmi output (dolby digital plus is an example of a discrete 7.1+ channel surround format, such as on blu-ray and hd-dvd discs). otherwise then youre limited to 5.1 compressed surround (standard ac-3/dts, due to coaxial/optical not having enough bandwidth for more, and even standard video dvds simply not having enough capacity (with both video and audio on it)... 6.1 is possible though over coaxial/optical, but only if the surround format is encoded for it, such as with dolby digital ex or dts-es)
Message edited by choirbass on 08-15-2007 at 12:54:37 AM
Reply to choirbass
- 0 +
Your av receiver must have hdmi audio switching if you go down the hdmi route not just video switching. Otherwise it cannot remove the auidio signal.
Reply to gpippas
ok. i was just pointing out why he wasnt getting more than 2 channels, and what it would take to get more. im not positive, but i dont believe anything less than hdmi will even work for a 7.1 surround format. spdif might work though if the audio is more compressed, but probably not otherwise, drm also might also be interfering, because hes not using hdmi (but im not sure if that only applies to vista or not)
edit: so, its sounding like youll need at least an hdmi output from your computer, and an hdmi input on your receiver, for the hd-dvd audio to work how youre expecting it to. this next part is probably a non issue since you already have the disc most likely, but youll also need an hd-dvd compatible player, but, im assuming you do already, so, yeah.
Message edited by choirbass on 08-15-2007 at 12:35:27 AM
Reply to choirbass
Thanks for the info.... no I have not solved the problem on my end. Even with DVDs or HDDVDs, I get stereo sound...
When doing the speaker test from the software, I only get sound from Front Right and Front Left.... My current solution has been to use DPL ][ which is okay, just not great... I will have to check the version of the drivers I am running and upgrade if possible.
Reply to obiwan05
as far as getting 5.1 surround from dvds over optical, you need to enable spdif passthrough/use external amplifier in your dvd playback software and speaker settings (options available will depend on the sound card software, and which dvd playback software youre using). enabling something like spdif passthrough will make it so your sound card settings are bypassed, so it wont matter whether you have it set up for 2 speakers, or 7.1 then... because only your receivers settings will then be used then to decode the dvd.
if you dont enable something like spdif passthrough, then your sound cards settings will continue to be used, and nothing will change from how it is now.
Message edited by choirbass on 08-16-2007 at 01:22:31 PM
Reply to choirbass
I have a similar problem:
I dont get surround-sound either! Just F***** stereo, and I have no idea why?!
my config:
Board (including sound): ASUS P5Q
Graphics card: Asus GeForce 9400 (including HDMI-output)
System: Vista-32bit
Drivers: Vista_Win7_R226.exe
Receiver: Onkyo 7.1, hdmi-in-and-output
My computer is directly connected to the receiver via hdmi!
Has anybody got an idea why my receiver just receives a stereo-signal? Do I need to change some settings or is it a hardware based problem?
Message edited by Anonymous on 06-10-2009 at 06:02:49 PM
Reply to Anonymous
All audio files for a PC are in 2.0, which is the default transmit mode for Spdif (Due to bandwith/space concerns). As such, unless you have software/hardware that supports real time encoding, all files from a PC will be transmitted in 2.0, no matter your connection type.
For analog connections, this is less of an issue considering all modern soundcards, and most discrete sound chips, support encoding to at least 5.1 (if not 7.1). For example, my Razer Barracuda HP-1 can upscale via Pro Logic IIX or DTS:Connect when I use an analog connection, but lacks any upscaling for a digital connection.
As for movies that you watch via your PC, DVD's/Blu-Rays store their audio data in one (or more) of several formats:
MPEG-2 (Not usually used)
PCM 2.0 (Most Common)
Dolby Digital 5.1 (Usually on disk as secondary format)
DTS 5.1/6.1 (Sometimes used in place/alongside of Dolby Digital)
Other 7.1 formats (True HD, Dolby Digital Plus, etc)
Note that PCM audio above 2.0 is very rare, due to space concerns.
To get 5.1 sound, first you need to ensure the disk has a 5.1 track, your decoder (reciever) can decode the format, and the player is set up to play back the 5.1 track. I know the player I used simply checked the Windows Control Panel to see what setup I was currently using (In fact, there are options in the advanced tab to check weather or not Dolby Digital and DTS are supported by your reciever, probably for this exact purpose). If these conditions are not met, your only option is to upmix the signal to 5.1 (see above section).
Message edited by gamerk316 on 06-10-2009 at 08:26:58 PM
------------------------------ http://valid.canardpc.com/cache/banner/1647132.png
Reply to gamerk316
the disc has 5.1 track
my receiver can decode the format dolby and dts
in the windows control panel i can just tick stereo, whearas under properties i can tick dts and dolby (it works!)
so the problem must be the player!
Which player would you advise me to use and under which configuration? I have some problems with my vlc, any alternatives?
Thanks a lot!
Reply to Anonymous
- 0 +
I was going through the same thing and to make the long story short I solved it with the SPDIF pass through.
1- Install klite codec pack full
2- Play the file through Windows Media Player and open the blue icon next to the time in the bottom right labelled as "FFA"
3- In that dialogue box you will find an "output" option, in that option there is a passthrough settings.
4- Select the settings of your choice and enjoy the true surround sound
If that does not work then try a program that encodes AC3 Live and then outputs it through SPDIF or COAXIAL. "redocnexk"
Get it here:
http://www.driverheaven.net/genera [...] coder.html
Reply to krx2m
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 2025 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 5 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
