Just built a new system:
ASUS Crosshair MOBO
AMD 2.8Ghz Dual Core CPU
2 x 1Gb Ballistix RAM
XFX 7950 GT GPU
PC Power & Cooling 750w PSU
2 x DVD drives
3 x HDD
1 x Floppy
The Asus only has 1 onboard IDE connector, so I have put both my DVD drives on that.
Now the problem!
Because the onboard IDE is now taken up with the DVD drives, I have to connect my 3 HDD's to a PCI A-Bit HotRod 100 Pro IDE Raid card that I used in the previous system to access a spare HDD, this is not being used as a RAID controller, just an IDE controller and does not work with IDE CD or DVD drives! This has 2 channels and supports 4 HDD's, so I've connected my boot drive to the Primary Master and the system boots. However, if I connect ANY other drive, be it a slave on the primary channel or Master/Slave on the Secondary channel I just keep getting Boot Failure messages?
The 2 other HDD's have been formatted as pure data drives, no active partions just an extended DOS partion. The onboard BIOS for the card allows me to select a boot drive, so I set Primary Master to boot but it won't boot if I connect 2 or more drives to this card? So I can get my boot drive working but not with the other 2 HDD's I need.
It's driving me crazy!! Any ideas on what the problem may be please?
ASUS Crosshair MOBO
XFX 7950 GT GPU
2 x DVD drives
3 x HDD
1 x Floppy
Now the problem!
