Having a bit of a connection issue with a game. (Dark age of Camelot specifically) I constantly go linkdead and their online support says I should upgrade router firmware (done) and my onboard ethernet drivers. (in process of and I am using onboard lan)
But what I don't understand is what to do with that information. I used it and it times out after a several jumps. But how does this help.
Thanks any tips would be appreciated. The support pages also recommend leaving onboard ethernet behind and buy a separate nic. Since its an older computer I completely forget what version of the nforce I have and I am not sure if I am doing this correctly
Any thoughts?
Message edited by arson on 04-07-2008 at 10:09:42 PM
Try a different netowrk cable. If using a router take it out of the config to check it. If it still fails buy a pci nic card and see if problem is fixed. If so then its possible the nic is going bad on the motherboard.
