Archived from groups: alt.games.coh (More info?)
Greetings all,
I am hoping that the readers of this forum can help me, as those at CoH
technical Support have not.
I enter the game with no problems, however after being in game for 30 - 45
minutes or so I begin to experience terrible lag and my frame rate drops
dramaticly (sometimes 1 FPS). This seems to happen much more quickly when I
am grouped.
I can log out of the game and restart the application and have another 30 -
45 mins of little lag, but then it starts all over again.
My drivers are up to date, I have kept my system defragmented, and went so
far as to reformat my system in an attempt to correct this. The only running
processes are Microsoft processes. My paging file is set at 2048 MB. I have
a DSL connection and am using a Linksys 4 port router, there are 3 computers
on the network, two of which are used for CoH.
To be honest I am coming to the end of my rope with this problem and CoH.
None of the other games I play have this problem. I like CoH, but cannot
rationalize paying for a game that I cannot get to work properly.
Any help would be greatly appreciated. Dxdiag, Hijackthis, and
Networkinfotool logs below. (note that Norton AV was turned off in these
logs due to disabling all services that were not microsoft, and have been
reactivated since)
Thanks in advance
System Information
Time of this report: 4/30/2005, 13:15:33
Machine name: JKL
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2
(2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: ASUSTeK Computer INC.
System Model: A7N8X
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) XP 2100+, MMX, 3DNow, ~1.7GHz
Memory: 1024MB RAM
Page File: 135MB used, 2838MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found. DirectDraw test results: All tests were
successful. Direct3D 7 test results: All tests were successful. Direct3D 8
test results: All tests were successful. Direct3D 9 test results: All tests
were successful.
Sound Tab 1: DirectSound test results: All tests were successful.
Music Tab: DirectMusic test results: All tests were successful.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce FX 5200
Manufacturer: NVIDIA
Chip type: GeForce FX 5200
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0322&SUBSYS_203C1682&REV_A1
Display Memory: 256.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Hansol Mazellan900P
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.7189 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 4/1/2005 16:16:00, 3980288 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 4/1/2005 16:16:00, 3454656 bytes
Device Identifier: {D7B71E3E-4062-11CF-2769-360000C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0322
SubSys ID: 0x203C1682
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC722-3235-44A4-BD29-E1652BBCC71C}:
Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,2)
Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2)
Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB
VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2)
Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB
DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY)
Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB
VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY)
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY)
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659)
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659)
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659)
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e)
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e)
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e)
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: All tests were successful.
D3D7 Test Result: All tests were successful.
D3D8 Test Result: All tests were successful.
D3D9 Test Result: All tests were successful.
Sound Devices
Description: SB Audigy Audio [D000]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0004&SUBSYS_00511102&REV_03
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 5.12.0001.0443 (English)
WHQL Logo'd: Yes
Date and Size: 2/23/2004 15:11:46, 366352 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 191999
Static/Strm HW Mix Bufs: 64, 62
Static/Strm HW 3D Bufs: 64, 62
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: All tests were successful.
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: SB Audigy DirectMusic Synthesizer [D000], Hardware (Kernel Mode),
Output, DLS, Internal, Default Port
MPU-401, Hardware (Kernel Mode), Input, No DLS, External
MPU-401, Hardware (Kernel Mode), Output, No DLS, External
SB Audigy Audio [D000], Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No
DLS, Internal
SB Audigy Synth A [D000] [Emulated], Hardware (Not Kernel Mode), Output, No
DLS, Internal
MPU-401 [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
SB Audigy Sw Synth [D000] [Emulated], Hardware (Not Kernel Mode), Output, No
DLS, Internal
SB Audigy Synth B [D000] [Emulated], Hardware (Not Kernel Mode), Output, No
DLS, Internal
SB Audigy MIDI IO [D000] [Emulated], Hardware (Not Kernel Mode), Output, No
DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode),
Output, No DLS, Internal
MPU-401 [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
SB Audigy MIDI IO [D000] [Emulated], Hardware (Not Kernel Mode), Input, No
DLS, External
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x0067
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/4/2004 02:08:42, 57600 bytes
| Driver: usbd.sys, 7/7/2003 08:00:00, 4736 bytes
Gameport Devices
+ PCI bus
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 8/4/2004 02:07:46, 68224 bytes
+-+ Standard Game Port
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 8/4/2004 02:08:22, 10624 bytes
+ PCI standard PCI-to-PCI bridge
| Matching Device ID: pci\cc_0604
| Service: pci
+-+ Creative Game Port
| | Matching Device ID: pci\ven_1102&dev_7003&subsys_00401102
| | Service: gameenum
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/4/2004 02:14:36, 52736 bytes
| Driver: kbdclass.sys, 8/4/2004 01:58:32, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 04:01:07, 40840 bytes
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 8/4/2004 01:58:32, 23040 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll
(5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll
(5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll
(5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll
(5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll
(5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll
(5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll
(5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll
(5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run,
Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 64.1 GB
Total Space: 76.3 GB
File System: NTFS
Model: WDC WD800JB-00FMA0
Drive: F:
Free Space: 140.7 GB
Total Space: 190.8 GB
File System: NTFS
Model: WDC WD2000JB-00EVA0
Drive: D:
Model: LITE-ON DVDRW LDW-811S
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English),
8/4/2004 01:59:52, 49536 bytes
Drive: E:
Model: LITE-ON LTR-52327S
System Devices
Name: Creative Game Port
Device ID: PCI\VEN_1102&DEV_7003&SUBSYS_00401102&REV_03\4&3B1D9AB8&0&4140
Driver: C:\WINDOWS\system32\drivers\gameenum.sys, 5.01.2600.2180 (English),
Name: OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1102&DEV_4001&SUBSYS_00101102&REV_00\4&3B1D9AB8&0&4240
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English),
8/4/2004 02:10:08, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English),
8/4/2004 02:10:06, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English),
8/4/2004 01:58:29, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English),
8/4/2004 01:58:29, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English),
8/17/2001 09:46:40, 6400 bytes
Name: Creative SB Audigy
Device ID: PCI\VEN_1102&DEV_0004&SUBSYS_00511102&REV_03\4&3B1D9AB8&0&4040
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004
03:56:42, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004
03:56:58, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English),
8/4/2004 02:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English),
8/4/2004 02:07:58, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English),
8/4/2004 02:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English),
8/4/2004 02:08:02, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004
03:56:57, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 5.12.0001.0444 (English),
2/23/2004 15:16:10, 645360 bytes
Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 5.12.0001.0443 (English),
Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 5.12.0001.0441 (English),
10/8/2003 10:06:50, 178672 bytes
Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 5.12.0001.0441 (English),
10/8/2003 10:08:12, 6096 bytes
Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 5.12.0001.0441 (English),
10/8/2003 10:09:10, 130288 bytes
Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 5.12.0001.0442 (English),
10/13/2003 17:42:12, 145488 bytes
Driver: C:\WINDOWS\system32\drivers\ha10kx2k.sys, 5.12.0001.0446 (English),
2/24/2004 12:17:10, 904784 bytes
Driver: C:\WINDOWS\system32\drivers\haP16v2k.sys, 5.12.0001.0442 (English),
10/21/2003 17:23:44, 148432 bytes
Driver: C:\WINDOWS\system32\drivers\pfmodnt.sys, 3.00.0000.0003 (English),
3/5/2003 15:07:46, 15840 bytes
Driver: C:\WINDOWS\system32\ctdlang.dat, 10/21/2003 17:54:50, 217272 bytes
Driver: C:\WINDOWS\system32\ctstatic.dat, 10/21/2003 17:47:40, 298971 bytes
Driver: C:\WINDOWS\system32\ctdaught.dat, 10/21/2003 17:47:34, 53932 bytes
Driver: C:\WINDOWS\system32\a3d.dll, 80.00.0000.0003 (English), 10/6/2003
14:38:06, 65536 bytes
Driver: C:\WINDOWS\system32\commonfx.dll, 5.12.0001.0440 (English),
10/6/2003 14:44:28, 114688 bytes
Driver: C:\WINDOWS\system32\ctaudfx.dll, 5.12.0001.0442 (English), 2/18/2004
15:38:32, 585728 bytes
Driver: C:\WINDOWS\system32\ctsblfx.dll, 5.12.0001.0440 (English), 10/6/2003
14:46:14, 606208 bytes
Driver: C:\WINDOWS\system32\sfman32.dll, 5.12.0001.0130 (English), 8/17/2001
14:35:46, 36864 bytes
Driver: C:\WINDOWS\system32\ctbas2w.dat, 10/21/2003 17:54:48, 140643 bytes
Driver: C:\WINDOWS\system32\ctsbas2w.dat, 10/21/2003 17:54:42, 264466 bytes
Driver: C:\WINDOWS\system32\SBAudigy.ico, 8/17/2001 12:42:28, 7406 bytes
Driver: C:\WINDOWS\system32\Audigy.bmp, 11/13/2001 09:48:20, 1912 bytes
Driver: C:\WINDOWS\system32\ctcoinst.dll, 3.00.0000.0005 (English),
2/23/2004 10:10:00, 73728 bytes
Driver: C:\WINDOWS\system32\ctdvinst.dll, 1.82.0000.0001 (English),
6/27/2003 17:51:42, 122880 bytes
Driver: C:\WINDOWS\system32\drivers\ctdvda2k.sys, 5.13.0001.0413 (English),
10/14/2003 11:17:56, 332800 bytes
Name: NVIDIA GeForce FX 5200
Device ID: PCI\VEN_10DE&DEV_0322&SUBSYS_203C1682&REV_A1\4&1B197270&0&00F0
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.7189 (English),
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.7189 (English), 4/1/2005
16:16:00, 127043 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0016 (English), 4/1/2005
16:16:00, 32256 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0016 (English), 4/1/2005
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.7189 (English), 4/1/2005
Driver: C:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.7189 (), 4/1/2005
16:16:00, 540672 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.7189 (English), 4/1/2005
16:16:00, 5332992 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0010.7189 (English), 4/1/2005
16:16:00, 5562368 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0010.7189 (English), 4/1/2005
16:16:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0010.7189 (English), 4/1/2005
16:16:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.10040 (English),
4/1/2005 16:16:00, 286720 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 4/1/2005 16:16:00, 165039 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 4/1/2005 16:16:00, 55444 bytes
Name: NVIDIA nForce2 Memory Controller
Device ID: PCI\VEN_10DE&DEV_01EF&SUBSYS_0C1710DE&REV_A2\3&13C0B0C5&0&05
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01EE&SUBSYS_0C1710DE&REV_A2\3&13C0B0C5&0&02
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01ED&SUBSYS_0C1710DE&REV_A2\3&13C0B0C5&0&03
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01EC&SUBSYS_0C1710DE&REV_A2\3&13C0B0C5&0&04
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01EB&SUBSYS_0C1710DE&REV_A2\3&13C0B0C5&0&01
Driver: n/a
Name: NVIDIA nForce2 AGP Host to PCI Bridge
Device ID: PCI\VEN_10DE&DEV_01E8&SUBSYS_00000000&REV_A2\3&13C0B0C5&0&F0
Driver: C:\WINDOWS\system32\DRIVERS\nv_agp.SYS, 4.12.0001.0278 (English),
9/5/2002 23:24:00, 13568 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_10DE&DEV_01E0&SUBSYS_00000000&REV_A2\3&13C0B0C5&0&00
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_006C&SUBSYS_00000000&REV_A3\3&13C0B0C5&0&40
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English),
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_0068&SUBSYS_0C111043&REV_A3\3&13C0B0C5&0&12
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English),
8/4/2004 02:08:37, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English),
8/4/2004 02:08:42, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004
03:56:46, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English),
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004
03:56:42, 7168 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_0067&SUBSYS_0C111043&REV_A3\3&13C0B0C5&0&11
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English),
8/4/2004 02:08:36, 17024 bytes
Device ID: PCI\VEN_10DE&DEV_0067&SUBSYS_0C111043&REV_A3\3&13C0B0C5&0&10
Name: NVIDIA nForce MCP Networking Adapter
Device ID: PCI\VEN_10DE&DEV_0066&SUBSYS_80A71043&REV_A1\3&13C0B0C5&0&20
Driver: C:\WINDOWS\system32\DRIVERS\NVENET.sys, 4.14.0001.0281 (English),
9/22/2002 22:37:00, 80896 bytes
Driver: C:\WINDOWS\system32\DRIVERS\jedih2rx.bin, 9/22/2002 22:37:00, 1024
bytes
Driver: C:\WINDOWS\system32\DRIVERS\ramsed.bin, 9/22/2002 22:37:00, 122
bytes
Driver: C:\WINDOWS\system32\DRIVERS\jedireg.pat, 9/22/2002 22:37:00, 42
bytes
Name: NVIDIA NForce MCP2 IDE Controller
Device ID: PCI\VEN_10DE&DEV_0065&SUBSYS_0C111043&REV_A2\3&13C0B0C5&0&48
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English),
8/17/2001 13:51:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English),
8/4/2004 01:59:41, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English),
8/4/2004 01:59:42, 95360 bytes
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0064&SUBSYS_0C111043&REV_A2\3&13C0B0C5&0&09
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0060&SUBSYS_00000000&REV_A3\3&13C0B0C5&0&08
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English),
7/7/2003 08:00:00, 35840 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 266240
bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 27136
bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 7/7/2003 08:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:41 1179648
bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:41 8192
bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:41 1689088
bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 7/7/2003 08:00:00 436224
bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:41 825344
bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 7/7/2003 08:00:00 590336
bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 7/7/2003 08:00:00 350208
bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 7/7/2003 08:00:00 47616
bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 7/7/2003 08:00:00 34816
bytes
dplay.dll: 5.00.2134.0001 English Final Retail 7/7/2003 08:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 229888
bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 23552
bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 7/7/2003 08:00:00 42768
bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 57344
bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:48 30208
bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:48 18432
bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 375296
bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:03 3584
bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:03 3584
bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 212480
bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:48 83456
bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 116736
bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 21504
bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 35328
bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 60928
bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 7/7/2003 08:00:00 53520
bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 159232
bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 181760
bytes
dimap.dll: 5.01.2600.0000 English Final Retail 7/7/2003 08:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 7/7/2003 08:00:00 394240
bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:57 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 7/7/2003 08:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:44 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/4/2004 02:08:22 10624
bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 367616
bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 1294336
bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 19456
bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 181760
bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 71680
bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 104448
bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 28672
bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 61440
bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 181248
bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 35840
bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 105984
bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 103424
bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 82432
bytes
system.dll: 1.01.4322.2032 English Final Retail 4/27/2005 08:04:46 1224704
bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 619008
bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 1227264
bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 2113536
bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 7/7/2003 08:00:00 924432
bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 03:56:42 1028096
bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 03:56:46 22528
bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:41 70656
bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:42 59904
bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 03:56:42 498205
bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:42 35328
bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:57 148992
bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:43 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 20480
bytes
qasf.dll: 10.00.0000.3646 English Final Retail 8/11/2004 01:45:04 221184
bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:44 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:44 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:44 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:44 562176
bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:24 733696
bytes
quartz.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:44 1287680
bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 03:56:45 246302
bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 03:56:57 199680
bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 03:56:57 848384
bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 03:56:42 120320
bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 03:56:42 338432
bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 03:56:42 755200
bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 03:56:42 200192
bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 03:56:42 183808
bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 03:56:57 154624
bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:44 204288
bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/4/2004 02:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:58 130048
bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/4/2004 02:08:02 48640
bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:58:38 5376
bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/4/2004 01:58:40 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:58:41 7552
bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:58:41 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:57 118272
bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:43 1428480
bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:57 30720
bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:44 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:46 50688
bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3646
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3646
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video
Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3646
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3646
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3646
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video
Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180
..RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
Uncompressed Domain Shot Detection
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00200000,2,2,,5.03.2600.2180
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2180
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180
Audio Capture Sources:
SB Audigy Audio [D000],0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2180
MPU-401,0x00200000,1,0,quartz.dll,6.05.2600.2180
SB Audigy MIDI IO [D000],0x00200000,1,0,quartz.dll,6.05.2600.2180
SB Audigy Sw Synth [D000],0x00200000,1,0,quartz.dll,6.05.2600.2180
SB Audigy Synth A [D000],0x00200000,1,0,quartz.dll,6.05.2600.2180
SB Audigy Synth B [D000],0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming Capture Devices:
,0x00000000,0,0,,
SB Audigy MIDI IO [D000],0x00200000,2,2,,5.03.2600.2180
SB Audigy Audio [D000],0x00200000,3,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
SB Audigy DirectMusic Synthesizer [D000],0x00200000,1,1,,5.03.2600.2180
SB Audigy Sw Synth [D000],0x00200000,1,1,,5.03.2600.2180
SB Audigy Synth A [D000],0x00200000,1,1,,5.03.2600.2180
SB Audigy Synth B [D000],0x00200000,1,1,,5.03.2600.2180
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
SB Audigy Audio [D000],0x00200000,1,0,quartz.dll,6.05.2600.2180
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
DirectSound: SB Audigy Audio [D000],0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming System Devices:
MPU-401,0x00200000,3,2,,5.03.2600.2180
SB Audigy Synth A [D000],0x00200000,11,2,,5.03.2600.2180
SB Audigy Audio [D000],0x00200000,13,2,,5.03.2600.2180
Logfile of HijackThis v1.99.1
Scan saved at 1:29:11 PM, on 4/30/2005
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\system32\CTHELPER.EXE
C:\WINDOWS\system32\RUNDLL32.EXE
C:\Program Files\Netropa\Multimedia Keyboard\MMKeybd.exe
C:\Program Files\Netropa\Multimedia Keyboard\TrayMon.exe
C:\Program Files\Netropa\Onscreen Display\OSD.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\Documents and Settings\L. Ruleman III\Desktop\HijackThis.exe
O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - C:\Program
Files\Norton SystemWorks\Norton AntiVirus\NavShExt.dll
O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} -
C:\Program Files\Norton SystemWorks\Norton AntiVirus\NavShExt.dll
O4 - HKLM\..\Run: [CTHelper] CTHELPER.EXE
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE
C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE
C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [MULTIMEDIA KEYBOARD] C:\Program Files\Netropa\Multimedia
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec
Shared\ccApp.exe"
O4 - HKLM\..\Run: [ccRegVfy] "C:\Program Files\Common Files\Symantec
Shared\ccRegVfy.exe"
O4 - HKLM\..\Run: [Symantec NetDriver Monitor]
C:\PROGRA~1\SYMNET~1\SNDMon.exe /Consumer
O4 - HKLM\..\Run: [MSConfig]
C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe /auto
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} -
C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger -
{FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) -
http://v5.windowsupdate.microsoft. [...] 4600798937
############### Beginning: Local IP Config
Windows IP Configuration
Host Name . . . . . . . . . . . . : jkl
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : NVIDIA nForce MCP Networking Adapter
Physical Address. . . . . . . . . : 00-E0-18-E5-1B-34
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 151.196.0.38
199.45.32.43
Lease Obtained. . . . . . . . . . : Saturday, April 30, 2005 9:45:26 AM
Lease Expires . . . . . . . . . . : Tuesday, May 03, 2005 9:45:26 AM
############### Ended: Local IP Config
############### Beginning: IP check
WAN IP: 151.205.138.246
############### Ended: end check
############### Beginning: NSLookups
IP Address Information: www.coh.com
65.205.186.54
IP Address Information: boards.coh.com
65.205.186.56
IP Address Information: cohupdate.coh.com
64.154.197.13
64.154.197.14
209.0.88.3
209.0.88.4
64.154.197.12
############### Ended: NSLookups
############### Beginning: CoH Updaters & Auth Port Tests
Check: cohupdate.coh.com (64.154.197.14) --> successful
Check: cohupdate.coh.com (209.0.88.4) --> successful
Check: cohupdate.coh.com (64.154.197.12) --> successful
Check: cohupdate.coh.com (209.0.88.3) --> successful
Check: cohupdate.coh.com (64.154.197.13) --> successful
Check: Auth Server Check (65.205.186.148) --> successful
############### Ended: CoH Port Tests
############### Beginning: Path Ping Tests
Route for Auth Server (65.205.186.148)
Tracing route to map.coh.com [65.205.186.148]
over a maximum of 30 hops:
0 jkl [192.168.1.100]
1 * * *
Computing statistics for 2 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
10/ 10 =100% |
1 --- 10/ 10 =100% 0/ 10 = 0% jkl [0.0.0.0]
Trace complete.
Route for West Coast (209.0.88.3)
Tracing route to cohupdate.coh.com [209.0.88.3]
1 * * *
10/ 10 =100% |
Trace complete.
Route for East Coast (64.154.197.13)
Tracing route to 64-154-197-13.plaync.com [64.154.197.13]
1 * * *
10/ 10 =100% |
Trace complete.
############### Ended: Path Ping Tests
> - 45 minutes or so I begin to experience terrible lag and my frame
> rate drops dramaticly (sometimes 1 FPS). This seems to happen much
> more quickly when I am grouped.
Man, I don't see squat wrong with your system setup. I think it's got to
be some kind of cache-loading problem, but damn if I can figure out why.
I know this is tedious, but try it: Go to some very low-traffic corner of
the map, like a corner of Galaxy City away from the noob mobs. Log out.
Log back in (to make sure you're clear). Do as little as you can for an
hour - just move around enough to keep from being autologged.
See when and if the framerate problems develop. If they don't after a
usual period plus a bit (which is why I say an hour) start doing things
normally and see how long the problem takes to occur.
If it happens even with no real "load" on your system, then it might be a
buggered network issue. If it only happens after a half hour of normal
playing, it's some sort of local cache issue. That's my best swing at
it...
-= Victory Server =-
-= Shenanigunner: Level 38 Natural Tanker, Fire/SS, M =-
-= Sgt Glory B: Level 29 Tech Blaster, Electric/Energy, F =-
-= RorShok: Level 17 Natural Scrapper, MA/SR, M =-
-= R A Heinlein: Level 8 Science Controller, Ill/Rad, M =-
-= Always looking for reliable teammates - look me up! =-
-= See you on HEROICA! - http://www.dgath.com/coh/ =-
-= The Keybind & Macro Guide is now available! =-
jklproductions@verizon.net wrote in news:EwRce.1862$k01.1849@trnddc03:
Have you tried posting it on the official forums?? That has helped some
people...
I know that there is currently an issue with shadows, and that some people
have found releif by turning off shadows under the Video and Graphics tab
of the Options menu.
Marcel and Moogli
On Sat, 30 Apr 2005 20:03:48 GMT, jklproductions@verizon.net wrote:
>Greetings all,
Unless I overlooked you saying that you've already tried it, run a
spyware and a virus scan.
Generic response, but usually catch
sources of such problems.
Dark Tyger
Stop the madness! (Marvel Vs Cryptic Studios petition)
http://www.petitiononline.com/marvscoh/petition.html
Hey, everyone else is doing it. Free iPod:
http://www.freeiPods.com/?r=15728814
"George Johnson" <matrix29@voyager.net> wrote:
> I'm on dialup and have a 128 MB Nvidia GeforceFX 5200.
> I turn off GEOMETRY BUFFERS and SHADOWS.
Shadows: understood. What does the Geometry Buffers setting do?
Shenanigunner <shenanigunner@NOdgathSPAM.kom> looked up from reading the
entrails of the porn spammer to utter "The Augury is good, the signs
say:
Frankly I can't remember, but it was one of the recommendations made
way, way back for people having graphic lag to switch them both off.
Another thing he might try is to turn the texture detail down to medium
- doesn't make a huge difference graphically but it seems to make a huge
difference in lag reduction.
Xocyll
I don't particularly want you to FOAD, myself. You'll be more of
a cautionary example if you'll FO And Get Chronically, Incurably,
Painfully, Progressively, Expensively, Debilitatingly Ill. So
FOAGCIPPEDI. -- Mike Andrews responding to an idiot in asr
On Sat, 30 Apr 2005 20:03:48 GMT, <jklproductions@verizon.net> wrote:
> Greetings all,
> 45
> when I am grouped.
I had a similar problem, admittedly with an ATI card, and installed an
alternative driver, the Omega from http://www.omegadrivers.net/ They seem
to produce alternative drivers for both NVIDIA and ATI, so it might be
worth a try. Some people also get faster performance from these drivers.
To this day I don't know why the game worked fine for the first minutes.
"When someone starts bragging about how much debt they have, it's not a
good sign." -G
There are 1216 identified and unidentified users. To see the list of identified users, Click here.
