Solved
Help laptop driver problem
Hi there at the moment i am using the on screen keyboard because all of a sudden my laptops keyboard and mousepd stopped working i am pretty sure there is something wrong with the drivers sice there is a yellow thing next to it i have tried system restore and evenuninsraller the keyboard driver but now i cant find it and i even took out the batteries and put them back in
if it helps my laptop is a toshiba
also sais This device cannot start. (Code 10)
You need to restart your computer before the changes you made to this device will take effect.
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
but nowthe ps/2 driver has dissapeared
thanks any help is appreciated
pasha
6 answers Last reply Best Answer
More about help laptop driver problem
  1. look for drivers here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
    i had a similar problem with a trackpad on an old laptop and i ended up reinstalling windows
  2. ok thanks ill check it out will update if works
  3. they didnt have my model so im still screwed
  4. Best answer
    try a repair install or a clean reinstall of windows
  5. ty jefe it works now
  6. Best answer selected by pasharahimi.
Drivers Laptops Keyboards Windows Vista
