Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > **HELP! TROUBLE RUNNING DUAL 22 INCH MONITORS
Forum Graphic & Displays : Graphics Cards - **HELP! TROUBLE RUNNING DUAL 22 INCH MONITORS
Hello,
I need some help haha
I Have a 1900gt and im trying to run 2 22inch monitors, when i connect both via DVI (card has 2 DVI ports) and I boot up one screen flickers, then the monitors will both go in and out of power save mode 4 or 5 times then just go black.... i got another 1900gt and tried it, with the same results. When I disable the second monitor it still does the same thing however when i physicly unplug the second monitors DVI connection the one monitor works fine.
I have tried everything i can think of, reimaging my whole PC incase it was software, rolling back the ATI drivers, changing the video card etc etc
the only other thing i was thinking is that it may be a power issue? i curren tly have a 500watt power supply.
Any help would be GREATLY appreciated
Thank you
Sponsored Links
There are 528 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
