I recently bought a bunch of brand new parts from TigerDirect and successfully put together my very first computer. It's a heck of alot faster then my old in every way but a seemingly all-knowing friend at work swears it's not getting the speeds it should be.
Problem 1:
My Hard drive is a SATA-II and from what I see (and my knowledge is short in this area), it's not running as SATA at all. This is from one of my utility programs...
Problem 2:
I run a server 24/7 but not alot of people play all at once. I usually have about 1400MB ram still free from running my server (and other small background stuff like anti virus). I recently have been playing a game called Second Life and about a week after playing, it started crashing. I'd get a popup in my toolbar saying I need to turn on my pagefileing. My old computer was ALOT slower then this computer and had almost 1/4 the memory (not to mention slower memory at that) And it seemed to run the server + a game just fine. Either Second Life or my background programs are sucking out all the Ram or ive got a problem of some kind. I know my server isn't a ram hog. I also keep a very clean computer so you can rule out a virus, spamware, spyware, or a cluttered registry.
Parts:
Case = Ultra XBlaster Clear Side Blk Mid-Tower Case
RAM = Crucial 1024MB PC5400 DDR2 667MHz (x2)
GFX card = NVIDIA GeForce 6800 GS 512MB PCIe w/DVI/TV-OUT
HardDrive = Maxtor 500GB Serial ATA II HD 7200/16MB/SATA-3G Model 7H500F0
CD/DVD reader/burner = Lite-On 16x Int SATA DVDRW Super-Multi SH-16A7S
PowerSupply = Ultra 600w V-Series DR PSU Black
Fan = Ultra Skt 775 Cooling Fan upto P4 3.8GHz
Processor = Intel Core2 Duo E6400 2.13Ghz Socket 775
Motherboard = Intel DG965RYCK Socket 775 Motherboard
O.S. = Windows XP Professional
Anti Virus = McAfee Security Center (Full)
I've been fighting problem 1 for a looong time now and problem 2 is getting annoying. I'll appreciate any help you can give.
Problem 1:
I have jumpers set on "Force 150" as recommended by many sites but it still doesn't seem to be pulling the speeds it should be. I ran some tests a while back and I was told it is indeed slower then it should be. I also have no idea about the drivers. I installed windows just like normal and my friend is telling me I don't have any sata drivers at all. I searched the disks that came with my system as well as the Maxtor and Intel sites for the drivers and came up with nothing. Any help?Max. Transfer Mode UDMA 6 (ATA/133)
Active Transfer Mode UDMA 5 (ATA/100)
Problem 2:
Parts:
