Hello, I just built my first computer and I'm a little concerned with my temps.
I have a Thermaltake BachXV case, Gigabyte GA-P35C-DS3R Mobo, Intel E6600 processor w/stock HSF, EVGA 8800GTS 640MB superclocked video card, Corsair HX520W PSU, 2GB ram, hard drive, dvd, etc
I've read through these forums some and have SpeedFan, TAT, CoreTemp95 and CPUZ installed.
My core0 temp (speedfan) will jump 7-8 degrees with the cover on my case. The case has a 140mm intake fan in the lower front and a 120MM exhaust fan upper rear. The fans have a 4-pin molex connector that I plugged into the PSU. There are connectors on the Mobo for fans; a 3-pin sys1, 3-pin pwr fan and a 4-pin sys2 fan.
I was wondering if I got an adapter (if available) and plugged the fans into the motherboard would that control the speed of these fans like it does the CPU? The fans run slow and "quiet" now. If I did, onto which connector? Would those cheap PCI slot fans help?
I'm not into overclocking "yet", But I might crank it up a little since I can. My temps running TAT as per cooling guide specs on this forum with cover on were; idle core0 speed fan 37, CoreTemp 42 TAT 43 load temps after 10 minutes were 66, 66 & 66.
If I try overclocking I would like to get my stock temps down a little and I figured the case needs to be cooler. I wouldn't think using hot air to cool your CPU is the best way, eh.
Sorry if I ran on too long. Any advice would be appreciated.
