Hi All,
I have a problem with my Coolermaster Wave case... had the case for 3 years and it has been good. Now, it is broken. I've finally figured out that the problem is related to a bad earth or grounding in the case.
Symptom is that when the system is powered up and the on button is pressed, the power hits the system for less than a second then stops. You can see the fans twitch, then nothing.
So I replaced pretty much the whole PC... including the power switch. In the process I've upgrade significantly, so all is not lost After having a chat with the very helpful guys at Asus, they suggested a case grounding problem. So I took out the components and put them on a non-conducting surface... and the system powered up fine.
Question is, how do I fix a grounding problem in a Coolermaster Wave?
Hope someone can help!
Cheers!
Cheers!
