ok well i have 3000 to spend no more, i have a monitor, speakers, and mouse..
I was looking to get the following
water cooled 8800GTX (bfg or evga cant decide)
680i mobo (bfg evga cant decide)
2x1 gig ram (i am really not sure what to get) (also i am probably going to upgrade later to 4gig when i get more money)
Q6600
not sure on hard drive(s) at the moment. is it worthwhile to get 2 cheaper hard drives and put them in raid 0, or get a wd raptor x for example??
as for the case i havent decided between a antec nine hundred or a danger den water box (which is really too expensive imo, being $200 and all, while the antec is $120 though im quite certain all this stuff wont fit in that case..)
and finally a danger den kit to cool the graphics card, cpu, and chipset. is all of this possible with 3k? if i can spend less that would be fantastic
*edit is it a realistic goal to hit 3.4 or so and keep it oc'd there forever?? and i was also wondering about the mobo southbridge and the (gah i forget name the power part right above the cpu that is rectangular, and runs super hot) do those parts need to be cooled or if i leave them stock is that ok?
*edit also when it comes to danger den stuff, does anyone have any suggestions for the right equipment i need. Because i dont want to go overkill but then i dont want to go under and not be able to cool all of the stuff properly.
thanks again
*o and i apologize for posting in this section but less people visit the other ones and i would like some good advice.
*like look how damn cool this looks:
http://www.dangerden.com/forums/viewtopic.php?t=8396
Q6600
thanks again
