I run into a problem with my new GeForce 7900GS KO card.
I downloaded UT2004 Demo and ran it and
was droping frames per second like crazy.
One millisecond it would be 40 the next 8 and so on.
It was jumping all over the place.
I uninstalled and reinstalled the game but that didn't fix the problem.
Anyone here know what the problem might be?
Is there a program I can run to check and see if this card is actually working right?
In UT04 you should really be hitting 85fps non stop with 6XAA and 16XAF ( I do any way).
well you can try using one of those banchmarking tools, like 3dmark05 or 06 and post up your result. Its not a sure fire way to see if your card is fine, but a very low score would give us some idea.
Ok I downloaded 3D Mark 06 and ran it.
The default screen resolution was set at 1280x1024
but my screen resolution is 1024x768. It wont let me
change it with out buying it.
Anyways here are the results with AA and Anisotropic Filtering Off.
3DMark Score 4665
SM 2.0 Score 1841
SM 3.0 Score 1818
CPU Score 2106
Return to Proxycon 14.865 FPS
Fire Fly Forest 15.811 FPS
CPU Red Vally 0.679 FPS
CPU Red Vally 1.044 FPS
Canyon Flight SM 3.0 16.091 FPS
Deep Freeze SM3.0 20.268 FPS
3DMark Score 8306 3DMarks
CPU Score 8862 CPUMarks
Detailed Test Results
Game Tests
GT1 - Return To Proxycon 37.0 fps
GT2 - Firefly Forest 25.0 fps
GT3 - Canyon Flight 39.7 fps
CPU Tests
CPU Test 1 4.6 fps
CPU Test 2 7.6 fps
What is your hole system?
Well your 3dmark scores are pretty good you should try different drivers.
I had an fx5200 not long ago, when i installed some drivers i wouldn't get good frames not even in cs1.6 when i changed them it would work fine again.
