Hi guys, I have a really bad issue with the directshow of microsoft. I play games (which requires DirectX and some that don't), the versions that uses DirectX are getting on hang at the startup (showing their splash screen and freezing with no crash message even after letting it breath over).
Getting DxDiag to work is getting me to crash at the 2/3 of the checking procedure and hangs, if I force shut it down and restart the dxdiag, it's telling me that a problem occured during the check and asks if I want to skip the directshow check.
Things already tried:
1. Drivers on/off (also 2 or 3 versions old tried) and cleaned.
2. DirectX re-installed (strange thing is that when running the install it keeps updating files everytime).
3. All the updates from MS are up to date.
4. Des-installed k-lite codec pack and re-installed (two versions prior too).
