I have two questions regarding power supplies.
1.) If I want to turn on an ATX power supply without it being connected to the motherboard, which pins do I short out on the 20-pin/24-pin ATX power connector? (either pin number or color) Was it purple and gray?
2.) This on is with regards to power usage. I know that the wattage of power supplies is determined by the maximum output of that power supply, but what about power usage on a light load?
For example: Say I have a 500 watt and a 1000 watt power supplies both rated at 80% efficiency. 300 watts of power is being drawn from each. Does the 1000 watt use more electricity to provide the 300 watts the computer is using or does it require the exact same amount of power that the 500 watt will be using (ignoring the fact that the 500 watt PSU is at a higher load percentage wise which usually means it will be less efficient at the higher load)?
In other words, will I use/waste more electricity buying a higher wattage PSU than a lower wattage one leaving all else the exact same?
Any help would be greatly appreciated, thanks!
-GWolfman
-GWolfman
