Im looking to buy a new graphics card my budget for the Graphics Card is £40 - £60(max)
Interface: Pci Express x16
Im not a heavy gamer, i use my pc mostly for Dvds, and Web designing and CSS sometimes.
Ive had a look online everywhere but i just dont know what graphics cards are good and what spec to look for can you help?
ALSO
Looking for a LCD monitor my budget it £150 - £250(max) ive seen the new Samsung SM226BW 22" Widescreen LCD Monitor but some reviews are sayin its a no no. Im not sure can anyone help! The monitor needs to have a DVI slot + support Dual Monitor!
Thanks In advance!!!
Message edited by phatbally on 07-10-2007 at 03:52:24 PM
how do i know what panel it is .. ie A or S? becuase ive been looking on websites and they majority of the time they dont tell you.
the graphics card on my computer at the moment is so bad that when i watch a dvd you can see ripple effects on the screen, its a onboard graphics card just now. The system was orignally a Server.
You can't know before you buy. You'll just have to see which one you get and if you get the S version, then just return it. You're lucky to be living in a country where that is possible..
If all you do is watch DVD movies, then just buy the 8500GT or the 2600 Pro.
8800GTX dude, id go for the X2900XT with 1gb of mem cuz of the amount of textures that will have to be rendered on such a large display but its up to you. two of either card is overkill and stupid, if you have money left over throw it at an after market cooler or in the bank.
Sapphire Technology ATI Radeon HD 2600 Pro 512MB PCIE Dual DVI TVO for £64.13 vac incl.( http://www.dabs.com/productview.aspx?quicklinx=4LH8 ) ( you said u watch movies right? well the HD2600pro is ideal for your application because it decodes far better then the 8000 cards from mean green)
All whithin budget!!!!
Message edited by BigCharb on 07-10-2007 at 05:27:37 PM
