Monitor problems question
Hello,monitor is blurred
2 answers Last reply
More about monitor problems question
  1. Really, we need more information :]
    OK, have you installed the drivers?
    How long have you had it? New?
    What make, size?
    What resolution is it set to?
    I presume you're using Windows Vista.
    What GPU are you using? Maybe give us some specifications on your entire system is nice. :]
    What cable are you using?
    What refresh rate is it set to?
    Sorrii to throw so many questions. Answer what ou can and that'll be useful. :]
  2. Clean it :lol:
    Check the desktop resolution. If it's not the correct resolution for your monitor, it'll be blurred/distorted.
Monitors Windows Vista
