Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Probably a simple thing with my monitor
Forum Graphic & Displays : TV/Video Cards - Probably a simple thing with my monitor
I currently have a dell 3007wfp monitor(30 inches, dual link dvi cable, 2560x1600 resolution) and I have it hooked up to my pc working perfectly. I would also like to hook up my 360 to the monitor so i bought a dvi to vga adapter and the vga adapter for the 360 but i am getting no picture. http://www.newegg.com/Product/Prod [...] 6812119042 that is the adapter I bought but I think it might be the wrong 1 due to the fact that my monitor has a dual link dvi cable and the adapter is an analog? but I am not sure so I was wondering if anyone could answer this.
------------------------------ Q6600 @ 3.0ghz, 2xpny pc8500 @ ddr2 533 5-5-5-15, raptor 150 gb, 2x 2900 xt, badaxe2, Creative SB-XFI Elite Pro, Dell 3007wfp, Silverstone 1kilowatt psu, Windows Vista ultimate 64 bit.
Sponsored Links
Yea if you are using a DVI-D cable then that particular cable doesn't carry analog signals on it. You'll need a DVI cable that has the 4-pin section on it as that is the part where the analog signal is transmitted.
------------------------------ http://miniprofile.xfire.com/bg/bg/type/2/itneal2277.png
Reply to itneal2277
could you possibly help me find the perfect adapter i need? preferably dvi female(the same one as video cards have so I dont have to hook it up to the back of the monitor) and male/female vga because i have the sex converter.
Reply to Romstar
http://img391.imageshack.us/img391/167/1211904205qd2.jpg
You need a DVI cable that has these four pins on it. With out it you will be unable to output to analog VGA.
This one should do http://www.newegg.com/Product/Prod [...] 6812119046
I'm assuming your using a cable similar to this http://www.newegg.com/Product/Prod [...] 6812712025
Reply to itneal2277
well I need a dvi to vga adapter since the one I have is analog I guess I need DVI-D to VGA preferallbly dvi-D female to vga male that wont i just hook it up to the cable and not to teh back fo the monitor. And my dvi to vga converter has those 4 pin things and it still doesnt work, plus my monitor doesnt even have 4 pins there to plug in those things just the flat long thing.
Reply to Romstar
Or this adapter http://www.newegg.com/Product/Prod [...] 6814998101 along with a VGA cable to your monitor should work.
Reply to itneal2277
ok so for this one this is exactly how it will work. On the back of my monitor it has a male DVI-D thing and that is where i'll put this and then hook up the 360 vga cable to the other side. So it will work perfectly and I will get picture?
Reply to Romstar
I probably should of asked this earlier but what version of Xbox 360 are you using? Core, standard, or elite?
Reply to itneal2277
the 400 dollar one.
Reply to Romstar
Alright I have to apologize, I should of looked up the specs to your monitor before posting. There has been a misunderstanding on my part. I assumed that your monitor either had an analog VGA connection on it or a DVI-I connection so somehow it could take an analog signal from your XBOX 360. Unfortunately your monitor doesn't appear to be able to take any analog signals since it just features an DVI-D connection. I do not know of any device or adapter that can take a VGA signal and then output to DVI-D. I asked which version of the XBOX 360 you have because the Elite version is the only version that features an all digital HDMI port, which can easily be converted to DVI-D through an adapter. Once again I apologize for the confusion.
Reply to itneal2277
damn so i need an hdtv thx for telling me though.
Reply to Romstar
One last thing you may want to consider, but I'm not entirely sure will work, is a high end A/V receiver. I believe they are capable of taking in one video source and then converting them to another. I personally have never used one but they may do what you need. One that looks capable http://www.newegg.com/Product/Prod [...] 6882103262. Just use the HDMI to DVI-D adapter on the HDMI output and it may work. Like I said my experience with these is limited and I would highly recommend consulting someone with more knowledge of receivers before trying anything.
After looking at the cost, you may be better off just getting an HDTV. :D
Reply to itneal2277
lol...... thx anyways man.
Reply to Romstar
There are 828 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
