3Ds Max Problem, help..!!
Hello guys,
I am new to this software, and wanted to do some animation stuff for the school.
I'm done with almost everything, and I need your help for the final effect.
There's an object, which i need to twist.
This can be done by (Modifier list=> Twist)
But the object is getting twisted from both the sides, actually i want it to be twisted from only one side, the other side should remain stationary.
Please help guys, how can I go for it??
Any help would be appreciated..!
1 answer Last reply
More about problem help
  1. I think what you need to do is set a pivot point at the place where you don't want it twist. I.e. you are essentially twisting around that side.
    Maybe have a look at this tutorial. It mentions twisting and pivot points.
Software Apps
