Tom's Hardware > Forum > CPU & Components > CPUs > Help With q6600 temps! 68!
Forum CPU & Components : CPUs - Help With q6600 temps! 68!
Hey I just put together my new system:
Gigabyte GA-965P-DS3
Q6600
Tuniq 120
2 Gig Gskills
700w thermaltake power
And my Quad temps are at 68! And I haven't even overclocked anything yet. I really need some help, suggestions, anything please!
Sponsored Links
I was going also going to use a TUNIQ on a 965-ds3 with a q6600 B3, I guess i'll have to wait for a g0 or get a LCS.
I'm now looking into a Kandalf LCS. it has a BIG radiator.
Thanks for the post. :hello:
Message edited by middlemarkal on 07-23-2007 at 03:37:29 PM
Reply to middlemarkal
Do you have fans on the Tuniq? Q6600 cannot be passively cooled. If you do, check if the heatsink properly attached on the M/B. If it is, then check your case flow.
You should be able to hit 40C idle with Tuniq.
Reply to yomamafor1
There are 978 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
