I've been having this problem where the mouse will jump around the screen beyond my control. Usually never when it's stationary, but when I'm trying to move the mouse around it will often jump to the corner of screen. It's been an ongoing problem for several years that has lasted through several reformats and more than one mouse (I think). The frequency of the issue ranges from every couple of minutes to a couple of times a minute. The problem also occurs in games where when you are trying to aim, the cross-hair will jump to the ground or the sky, or in some severe cases, it will jump to the corner and your character is stuck spinning and looking at the ground or sky.
The mouse does not get stuck in the position that it jumps to, it just gets really annoying when you're trying to drag files or something and the mouse repeatedly jumps to the corner of your screen.
I am unsure as to the problem and didn't see any forums about mouse hardware, and figured it was a software problem anyways. I apologize if this is not the correct forum to post in.
I was also unable to find any drivers for my mouse the Logitech UtraX Optical Mouse (did not come with UltraX keyboard). I am not sure if the issue is with the drivers though. I am using whatever mouse drivers are compatible with Windows XP Pro plug-in & play.
My computer specs are as follows (the machine is approx. 7 years old):
AMD Barton 3200 2.4ghz 400fsb
Kingston Tech DDR 2x512mb
ATI Radeon 9600XT 512mb
ASUS A7N8X-E Deluxe
please let me know if you need any other hardware details, I can look them up but that's all I can recite accurately off the top of my head.
ASUS A7N8X-E Deluxe
