Tom's Hardware > Forum > Smartphones & PDAs > Handhelds General > Visor locked in bootup, help!
Forum Smartphones & PDAs : Handhelds General - Visor locked in bootup, help!
Archived from groups: comp.sys.palmtops,comp.sys.handhelds (More info?)
My Visor just crashed for the zillionth time in OmniRemote, but it's stuck
in bootup after I pin-hole reset it. Is there any way to get it out of it
without doing a hard reset and toasting everything in RAM? Also, will
holding the power button while doing the pin-hole button do that? It's
never needed it, so I dunno if it's the same as my Treo (which has needed
it more times than I can count).
_____________________________________________________
For email response, or CC, please mailto:see.my.sig.4.addr(at)bigfoot.com.
Yeah, it's really a real address :)
Sponsored Links
In article <gbchu0hd96iu2r1tpani8plcf98bqmosng@4ax.com>,
My Visor eventually reached a condition where it would get into that mode--
stuck in a loop at pinhole reset--way too often. Hard reset was the only
way I could find to break the loop. You can't even turn in it off! I
solved the problem by getting a Clie.
Please reply to: | "When the press is free and every man
pciszek at panix dot com | able to read, all is safe."
Autoreply has been disabled | --Thomas Jefferson
Reply to Anonymous
Yes, there is. Hold the "up" button while you are resetting it using the
reset hole. Keep it pressed for a few seconds or until you see a Palm
logo. That way you will bypass any programs which start right after the
reset (like resident programs, hacks and so). All data in memory is intact.
If that doesn't help, then your only option is hard reset - you
described it down there. :)
> Also, will holding the power button while doing the pin-hole button do that?
No, it will invoke a hard reset procedure. PalmOS will ask you if you
want to erase all memory contents or not. If you wan to, press "up" or
any other key not to erase it.
Remove "/\" from e-mail address to correct it!
Reply to Anonymous
Archived from groups: comp.sys.handhelds (More info?)
Ah, thanks :)
BTW, it seems to me that I hit the power and up button at the same time
(remembering this procedure incorrectly) and it seemed to do something,
but I can't remember what because it was too long ago.
Am I just shorting a neuron here, or does that do something too?
Reply to Anonymous
Not sure, probably the same thing as one of this two:
a) holding just power button, waiting for logo, releasing and THEN
pressing up => erasing all memory to the factory state
b) holding just up button, bypassing all the resident hooks & vectors,
thus bypassing all programs starting with OS
I wouldn't try to reproduce it (because of a) unless the memory contents
isn't important to me. :)
Sorry for my bad memory, it was a long time ago, I'm using Tungsten|E
for some time now, and even while I used Visor I wasn't resetting it so
often.
Here you have a description of all three types of reset:
http://www.niles-hs.k12.il.us/tech [...] greset.pdf
Reply to Anonymous
Archived from groups: comp.sys.palmtops (More info?)
On Sat, 15 Jan 2005 14:27:18 +0000 (UTC), nospam@nospam.com (Paul Ciszek)
spewed:
Well that's not encouraging!
Yeah, that's exactly what happened, won't turn off, won't even boot to
safe mode (if that's hold up button while pin-hole reset, as I've heard).
I wonder what the hell is the deal with Palm OS. It seems to just get
"bit rot" like Winblows does, only you can't reinstall it to fix it like
with Windows!
Palm OS is just an absolute mess IMO, and OS5 is 5 times worse.
Is Clie M$ W-CE or still Palm?
Thing is, I hate to switch because of the incredible software choices for
Palm, and free availability (read: warez :)
Reply to Anonymous
My OS5 Zire72 has never needed a hard reset. It's very stable.
If you run pirate warez software, that's probably your problem...
Reply to Anonymous
On Sat, 15 Jan 2005 23:02:46 GMT, AaronJ <noemail@noemail.com> removed
the duct tape and proclaimed:
Hahahahaha! Good one.
I put 2 and 2 together and got 22.
Reply to bruno
On Sat, 15 Jan 2005 13:40:49 -0800,
see.my.sig.4.addr@nowhere.com.invalid removed the duct tape and
proclaimed:
Some would say that there is actually more PPC warez. Not that I
condone this stuff.
Reply to bruno
On Sat, 15 Jan 2005 23:02:46 GMT, AaronJ <noemail@noemail.com> spewed:
I disagree, I've had just as many problems if not more with freeware,
demo's, payware. In fact the worst problems I've had have been with
Pocket Tunes, which I got legit from Palm for registering.
So, definitely no correlation between warez/non.
In light of the above, there doesn't even seem to be any connection
between major software co's and no-name ones.
There seems to be no rhyme or reason to it at all!
Reply to Anonymous
On Sat, 15 Jan 2005 18:32:45 -0500, Bruno <insert@address.here> spewed:
>condone this stuff.
What'r the NG's? I see tons of palm stuff..
I dunno though, I just HATE to reward M$ for anything.
Plus, I've heard at least one horror story similar to my Palm experience
with PPC's (constant crashing). I'd sure hate to climb out of the pot and
into the fire!
Reply to Anonymous
>I disagree,
No, I think we agree:
>demo's, payware. In fact the worst problems...
If you have just as many problems with legit software as you do with warez
software, then you seem to agree there are lots of problems with warez software.
That's what I said: Warez pirate software probably is the problem... ;)
Reply to Anonymous
On Sun, 16 Jan 2005 20:22:53 GMT, AaronJ <noemail@noemail.com> spewed:
>>I disagree,
It would be more correct then to say that I've have problems with ALL
types of Palm software, regardless of source (wares/legit/free)!
IOW, I disagree!
Reply to Anonymous
If you have problems with *all* types of Palm software, then it's probably not
the software that is the cause of the problem... ;)
Reply to Anonymous
There are 1108 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
