My old rig I build 2 years ago.
AMD 64 3600
AN85X AMD Mobo http://www.ncix.com/products/index.php?sku=16654&vpn=A8N5X-UAYVZ&manufac ture=ASUS
2 gig ram (generic crappy ram)
ATIX1600 PCIE
80 gig harddrive western digital
sound blaster card (crappy)
This coming winter I want to rebuild but keep as many parts as I can including the motherboard, hard drive, and ram. However, after some thought I was wondering if it would be wise to upgrade the cpu without upgrading the mobo? The mobo's specs include AMD 64 X2 processors so I don't think its an issue of compatibility, since I am wanting to get like a AMD 5000 (or something like that). http://www.newegg.com/Product/Product.aspx?Item=N82E16819103759
This is an AM2 cpu which I am assuming is compatible.
So do you recommend getting a new motherboard? Since I haven't had a dual core cpu with this mobo before I just want to avoid any headaches, you know.
I guess what got me worried about the mobo was that it isn't even listed at newegg, so I don't think Athlon even sells it anymore!
So if you recommend I dump the A8N5X, what other mobo would you suggest? Chosing a good motherboard is the hardest thing for me. I never had many problems with Athlon so I have always stuck with them. I am adverse to change
AMD 64 3600
ATIX1600 PCIE
