i believe i have the older b3 or whatever its called stepping instead of G0 so im told it runs a bit hotter.. i have the tuniq tower by the way
on speed fan:
system: -3c (why the strange temp?? can somone explain this to me) cpu: 39 (is this ok seems a bit high to be quite honest since the tuniq tower is about equal to the thermalright ultra 120... AUX: 44c (idk what AUX is so is this alright?) core 0: 31 core 1: 30 Core 2: 28 Core 3: 27
at only %25 cpu usage i get these temps: cpu: 51 AUX: 45c core 0: 41 core 1: 37 Core 2: 37 Core 3: 37
and when i overclocked to 3Ghz i get these as idle temperatures:
ok i also had a question about memory and weather or not i should run it at 1:1 or auto...
*ok i tried to boot at 1:1 which meant i had to put FSB memory clock mode to link instead of unlinked and when i tried to boot i got this one long continuous beep so i have no idea whats wrong.. and to be quite honest i nearly had a heart attack when i heard that beep.. so please any help would be much appreciated, thanks
*haha and now lol i cant even boot up with 3Ghz, because my ram goes to 1333 or something like that... what should i set it to?? 800 or something?
Message edited by Maverick7 on 07-27-2007 at 09:23:11 PM
ok i set my ram to 800 now so i was able to boot but in cpu-z it says under memory
400.0 MHz FSB: DRAM 5:6 5 5 5 18 22 2T
now im still learning but shouldnt the FSB: DRAM be 1:1?? and if so when i try to set it to 1:1 it automatically sets the ram to 1333 MHz so is it then impossible to get to 1:1 or?? uhhh im so confused help please
Message edited by Maverick7 on 07-27-2007 at 09:33:10 PM
