Hi all. This will be my first self-build and I'm replacing my old P4 3.0GHz system. I've tried to do some reading, etc but could really do with some advice/comments now that I have an initial spec put together. Here's what I'm thinking about - please feel free to make any alternative suggestions (especially on the choice of MB & PSU if it seems underpowered)...
Antec 900 Gaming Case - £64.50
E6420 - £113.85 (this may come down next week)
GA-P35-DS3R - 83.43
Hiper HPU-4M580 - £48.12
2GB (2x1GB kit) Crucial Ballistix PC6400 - £85.00
HIS X1950XT 256MB - £111.32
Seagate Barracuda 7200.10 250GB - 43.82
Optiarc 7170S DVD/RW OEM - £19.85
Floppy Drive - £4.34
Arctic Silver 5 - £4.45
It's for general home use and particularly for gaming. I'll be sticking with 32-bit OS until there's a need to change.
I intend to do some light overclocking on the CPU (when I learn how!) but only basics. May decide to upgrade CPU to quad in 12-18 months if need be. Is the mobo the right sort of choice? The next model (P35C) apparently also supports DDR3 - is that right and should I get that? Will the PSU be suitable? Can I rely on onboard sound nowadays (currently use a Soundblaster Audigy 2)?
So, over to you - fire away! Am I on the right tracks? Any suggested alternatives? Anywhere I can try to trim the budget slightly without too much sacrifice?
Thanks in advance all (Let me know if you need me to add links. They just didn't work properly when I tried to do that last night)
GA-P35-DS3R - 83.43
