Problem with my P5N32-E SLI
Ok so I think my PCI-E slots might me dead. I got my new PC and when I put my 8800gts in the monitor says no signal. So I tried my old 7900 out of my old PC thinking the 8800 was DOA. same thing. Its not the monitor because it works with other computers. So I'm thinking its the PCI slots.I tried it in all 3 none worked. But I noticed that the fan on the card is spinning. Is there a way to tell if they are dead for-sure? Could this be something else?
15 answers Last reply
More about problem p5n32
    Did you plug in the auxillary 12v power connectors from the psu to the 8800 video cards? Could be a number of things, but likely not bad PCIE slots. I would reset the CMOS jumper and default the BIOS. Upgrading to the latest BIOS might solve the problem too.
  2. Did you install the video card drivers?
  3. I tryed reseting the CMOS jumper same thing happened. I havnt installed an OS yet so there are no drivers yet. I'm going to try getting a new DVI cable thats all I can think of ATM
  4. Does it beep indicating it gets through POST or just spins fans and do nothing else? Don't see it mentioned so thought I'd make sure it even gets to the part where the vidcard is supposed to do anything :D
  5. Ok Well I got it to work by taking out the motherboard battery. It worked fine for a few days untill I put the 2nd RAM stick in and now i'm back to no signal. I tryed taking the RAM back out, even using a different stick, resetting tje CMOS jumper, Taking out the MB battery but its still nothing. No beeps nothing but pretty lights and spinning fans
  6. what kind of ram are you using?
  7. I'm using Gskill DDR2800 PC6400 1GBx2
  8. some one tole me it might be my PSU but i have a 600w and i only ahve a 7900gt in it
  9. The 600watt is good,I am using G.Skill to with no problem.
  10. I actually had a similar problem with my P5N32e SLI PLUS, and narrowed it down to my ram being bad which is odd since it was Crucial Ballistix ram and that's supposedly very good ram. The only thing that I could think of is trying your GPU in the other PCI-E slot. Sounds odd but who knows.
    Are you getting any beeeeeeeeeeeps?
  11. Nope no beeps at all. I've tryed different Ram and different GPUs in all the slots. I got it to work for a few days by resetting the BIOS battery and using only 1 RAM stick.Then when i thought all was good, i put in the 2nd stick and bamb no post no nothing. i tryed to every thing i did before to get it to work but with no luck
  12. Problem will be the board.
    I have gone through 2 of these boards in a week with exact same problem.
    Even changed PSU to a 1000w silverstone,swapped graphics cards etc.
    RMA the board to the palce you bought it from.
  13. Posted on 08-13-2007 at 01:44:26 AM profilShow BBCodeansweranswer +answer -MPFavoris
    Inform the moderators about this message
    I had issues with this memory, constant BSOD until i moved the sticks to the black slots. Then just fine.
  14. Posted on 08-13-2007 at 01:44:26 AM profilShow BBCodeansweranswer +answer -MPFavoris
    I'am running 4G's of the ram with no problems set at 4.4.3.5 2T.
Asus Monitors PCI Express Motherboards
