Tom's Hardware > Forum > Storage > General Storage > SCSI HBA Card Problems
Forum Storage : General Storage - SCSI HBA Card Problems
I am running an HP Proliant DL380 G4 server with an HP U320 64bit Single Channel SCSI G2 Host Bus Adapter. I am connected to five HP StorageWorks Ultrium 960 Tape Drives. I am getting a throughput of 240MB/s. When I plug the tape drives, using the same cables and termination, to the integrated 6i RAID controller I am averaging 500-600MB/s. The drive and HBA card are allegedly compatible according to HP.com. I am getting the following warnings using the HP Library and Tape Tools utility:
|__ Device Analysis : Passed with Warnings
||__ version: V23.07.2007
||__ Firmware rev G64D is up-to-date for Ultrium 3-SCSI as of Fri Apr 20 19:00:00 2007.
||__ Rule 19:
||__ The current SCSI configuration is likely to be limiting the performance of the drive.
||__ Please check that your HBA is the correct type for the drive and that the cabling is good.
||__ The SCSI configuration referenced is the one for which device analysis was run and/or the support ticket was pulled.
||__ If this is not via your backup server then you may not have an issue.
||__ Current SCSI configuration: narrow Recommended: wide
||__ Current SCSI transfer rate limited to: n/a Recommended: 320 MB/sec. or better
||__ The drives hardware compression algorithm is currently switched off.
||__ This was probably set by the backup software.
||__ The drive's setup has not been altered.
||__ There were 19 rules checked.
||__ Device Analysis completed, and warnings have been reported.
Has anyone else experienced anything like this? I have contacted HP but I am exploring other support avenues since it is taking them so long to work with me.
Sponsored Links
There are 1032 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
