Hey guys this is my first time here and this post might be a long one so read and plz help this will be my first ever built computer .
So far this is all the stuff im planning to get and will get all by September.
Case - Cooler Master Centurion 5 (Already Have It)
Power Supply - Mushkin 550 Watt (already have it)
HDD - Seagate Barracuda (ST3320620AS) 7200.10 320GB SATA NCQ 3.0Gb/s 16MB Cache (OEM)
Video Card -XFX GeForce 8800GTS nVidia 8800GTS Chipset (560Mhz) 320MB (1300Mhz) DDR3 Dual DVI PCI-Express
Sound Card -Creative Sound Blaster Audigy SE 7.1 Surround 24 Bit 96KHz EAX2.0 Sound Card (OEM)
DVD Burner x2- LG GSA-H62L SATA LightScribe DVD-Writer 18x DVD+R/-R 8x DVD+RW/6x DVD-RW 10x DVD+/-R9 Dual Layer 48x CD-R 32x CD-RW
Those are the ones i know for sure im getting the rest i have always changed and i cant make up my mind on which to choose so i hope you guys can help.
Ram - Thinking of getting a Mushkin 2GB kit of 1GB Each. The thing is i don't know if i should get it because i keep
hearing OCZ, Corsair, and all those popular brands of memory are good. So what is the BEST memory for gaming? I want to get at least 2GB no more or less than 2GB for now. Iv looked at Mushkin alot because i think its a good brand and i hear good reviews about it. What is the best Mushkin Series of memory for hard core gaming? I think ill be using a motherboard with PC- 6400 so make sure the memory is PC - 6400. And about mother board ill get to that last.
CPU - Hmmm the most important thing in a computer and more expensive. I know i want a Intel CPU so no AMD plz. The thing is iv been looking at the Intel Core 2 Quad Q6600 2.40GHz Socket 775 OEM Processor and waiting on the price drop. Should i just stick to this and get the Q6600? I really dont know much about choosing CPUs because there is alot of choose and lots of different models. What is the best CPU out there for gaming? I don't plan to OC because its my first build and i want to see how good it is before i start thinking of over clocking. I dont know much about Intel Core duo series but i know they are one of the best CPUS out there. So help me decide if i should stick to Q6600 or get one of the E seies. What is the E Series btw? is it that extreme one? i know there is 3 series extrme, quad, and i think the last one is duo. I dont need extreme becuase they cost like 1000+ So should i stick to Q6600?
CPU Fan - If i get the Q6600 ill be getting this fan. Zalman CNPS9500-Cu-LED Heatsink with 92mm Ultra Quiet Fan *For Intel Socket 775 and AMD Socket 754/939/940.
and finally the last one...
Motherboard - Out of all the things i said ill be getting what is the perfect motherboard for this build? iv been thinking about the XFX nForce 680i LT SLI NVIDIA Socket 775 ATX Motherboard / Audio / PCI Express / SLI Ready / Gigabit LAN / S/PDIF / USB 2.0 & Firewire / Serial ATA / RAID here is the link http://www.tigerdirect.ca/applications/searchtools/item-detailsInactive.asp?EdpN o=2959594
ok i think that is all the things you need to start up a computer ill be using Windows XP Home because i hear vista is not good and ill be waiting for the SP1 til i decide to get it now i have a few questions before i go.
1) iv been seeing XFX, EVGA, BFG in front of video card models and i want to know if they mean anything? What is the best one to get? can anyone tell me what one is the most good for gaming or do they all have cons and pros?
2) this is a noob question.. the case i have has a reset button.. what dose reset do? dose it work like a restart function? or dose it erase your hard drive.
ok i think thats all the questions i need to know so far.. ill post more if i come up with more anyways ill be getting all thses parts at Canada Computers and tiger direct because i live in Canada so i cant go to newegg. anything i should change or anything im missing plz tell me. thanks for all the help srry for the long post i just dont want to make serpeate topics about cpu, and all the things i asked help for thanks.
