Tom's Hardware > Forum > Storage > DVD/CD Writers > NEC Drive problems... DVD Burning
Forum Storage : DVD/CD Writers - NEC Drive problems... DVD Burning
So, My DVD Burner has worked fine for quite some time... I actually burned some data a couple weeks ago, but now it won't burn anything onto a DVD-R... CD-Rs work fine, just not DVD-Rs.. It reads previously burned media on DVD and CD.. It also reads Games and music CDs. So the only thing it doesn't do is detect blank DVD-R... When I right click on the drive in Mycomputer, it shows a Completely Blue circle, with 0 bytes on everything... thanks for your help ahead of time guys!
Sponsored Links
Could be the media, have you tried different brands of DVDs? Update the firmware. May just be heading south and a new one will cost you about $30, something like Samsung, Lite On, or LG
Reply to g-paw
Thanks for the advice, I figured those possibilities, I already upgraded my firmware on my NEC ND-3550A to version 1.7... Sorry I didn't say the model earlier... The variables I haven't tested are different media, and different computer (for OS, and mobo purposes). I've been looking at getting two anyways, so I might as well buy another, and if this one turns out to be bad.. so be it.. but if it's good, then I have two.
------------------------------ Athlon X2 4600+ Am2 @ Stock...
GA-M59SLI-S5
2GB Corsair PC-6400 5-5-5-12
eVGA 7900GT OC'ed
Reply to fender22
- 0 +
Always good to have extra parts for testing, at least as long as you know they're good :)
Reply to g-paw
There are 689 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
