Tom's Hardware > Forum > CPU & Components > Other Components > Having a problem choosing between monitors
Forum CPU & Components : Other Components - Having a problem choosing between monitors
Ok so I'm going to upgrade my 20.1 inch ws lcd to either a 24 or this 28 viewsonic
http://www.newegg.com/product/prod [...] 6824116079
ViewSonic VX2435WM Piano Black 24" 8ms
http://www.newegg.com/product/prod [...] 6824116084
ViewSonic VX2835WM 28" 3ms
I was hoping if any of you guys could tell me which would be the all around better product to buy, I'm planning on using this monitor for everything, Gaming, TV, Reg computer usage.
Since there price range is similar, and the 28inch is bigger I was considering that one, But however I know 8ms is better for tv viewing, but would it matter that much?
Thanks for any who reply
Sponsored Links
that 28" looks pretty promising. and 8ms isnt really better for tv viewing. the lower response time is the best. one thing you may want to consider is just how far are you going to be sitting away from this monitor when you're just using the computer to type or just do whatever.
Reply to drew455
There are 1263 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
