New Gaming Buildm need advice on parts
Last response: in Systems
July 23, 2007 10:36:17 AM
I'm planning to purchase these parts in a month, but i'm not sure about the motherboard and ram, so i need some help.
Specs:
Intel Q6600 2.4GHz
GeForce 8800 GTS 640 Mb OC
PATRIOT 4GB (2x2GB)DDR2-800 CAS-5
***MOTHERBOARD
Antec P182 Case
Corsair 620W
2x WD 200Gb 7,200 RPM
PRICE: ~$1550
***I'm thinking one of these but i dont know which one exactly, leaning towards the IP35 Pro but still unsure.
ABIT IP35 Pro $185 ------------concerned that it only supports DDR2 800
Gigabyte GA-P35C-DS3R $160 ------------Concerned that it may not support my RAM (see above)
Gigabyte GA-P35-DS3R $130 ------------Concerned that it may not support my RAM (see above)
I'm not planning on buying DDR3 ram in the next couple of years, but i may upgrade to 8 gb at some point. I'm planning to mostly play games with this and some multi-tasking as well. No video encoding or anything.
Please give some advice on the PC as a whole and on the mobos.
July 23, 2007 10:51:05 AM
For that much you should be able to afford a 8800 GTX at the very least,
here's what I recommend going with:
LIAN LI PC-60BPLUSII $130
Q6600 $273 (mwave.com)
4GB Crucial ballistix DDR2 800 4-4-4-12 $240
Corsair 620HX $130 (buy.com)
MSI 8800 GTX $480
500GB Samsung $110
Tuniq 120 Tower $60
MASSCOOL G751 Shin-Etsu Thermal Interface Material $5
$1558
Good luck.
July 23, 2007 10:55:32 AM
The P35C-DS3R is the same as the P35-DS3R only with 2 additional DDR3 slots. Probably not worth the extra $30 in most cases (here in the UK the difference is £2, which does make it worth the extra). :p
Dior's suggestions look great, although obviously the case is largely down to personal preference and you won't go wrong with the Antec P182.
July 23, 2007 2:06:33 PM
thanks,
do you recommend the Crucial ram over the patriot?
I've used corsair and patriot, but never crucial.
Also, do any of these ram (the one i picked & the one suggested) have conflicts with any of the 3 mobos?
And do i really need a cpu cooler if i'm not planning on overclocking?
July 23, 2007 2:28:48 PM
Yes i'd get the Crucial ( http://www.newegg.com/Product/Product.aspx?Item=N82E168... ) over Patriot, I'm not sure if it's gonna work on Abit board but it works just fine on the Ga-P35. Cooler isn't necessary if you don't overclock but it's nice to have if you change your mind :)
July 23, 2007 3:56:37 PM
I would go for the Crucial over the Patriot if they're both within budget, yes.
