1900MHz A64 X2: 677MHz CL4 or 800MHz CL5?
El Cheapo
11
Hi. :D
Could you guys clarify something for me?
If I use a 1900MHz A64 X2 for something like World of Warcraft will I be better off with 2 gigs of 667MHz CL4 or 800MHz CL5? I mean will there be a noticeable difference?
I'm trying to calculate how the ram will fit the processor. Are the following calculations correct?
667MHz: 1900 / 333 = 5,7. -> 6 multiplier. (1900 / 6) * 2 = 633.
800MHz: 1900 / 400 = 4,75. -> 5 multiplier. (1900 / 5) * = 760.
Thanks in advance.
GSTe
656
Not sure what the bus speeds and multipliers are for those CPUs, but there won't be any noticeable difference between those ram kits.
