Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > 8800 GTS 320 slow please help
Forum Graphic & Displays : Graphics Cards - 8800 GTS 320 slow please help
ok here goes i have evga 8800 gts super clocked and it isnt meeting the expectations of the benchies im seeing on games. my sys specs are as follows 170 opteron dual core 2mb L2 cache at 2400hertz,2gig ram 4x 512 sticks pc3200,7200rpm sata 3g seagate 320gig with 16mb cache,sound blaster audigy SE, 550 watt power supply with 2x pci-x connectors 2 18amp rails, and also a Asus A8N-VM-CSM mobo with 6150 onboard geforce graphics,nforce 430 chipset. with all up to date chipset,video,bios drivers. And im gettin like 60fps in Prey on the benchmark at 1024x768 with settings on low and every bench i see is around 156fps with same settings. Am i missing something here? i upgraded my 3700 A64 san-diego chip to the dual core optie and no difference really in company of heros im not even breakin 40fps on 1024x768 and all other bechies are around 63fps or so and thats with 4AA/16AF, im thinkin its my motherboard, its not the best gameing board buts it was the only thing i had at the time,any suggestions? also before the 8800 i had a 1950 pro 256mb radeon and still very crappy scores thanks guys
Sponsored Links
Remember when they do benchmarks they use top end cpu and ram etc.
Im thinking that its prob the cpu that is holding your fps up,try playing with the settings drop all AA and AF check to see if you fps go up a lot if they dont then its not the card also try winding settings up and see if the fps go down again if not it points to the cpu. Can you increase the res at all some times this helps to take the load off of the cpu and lets the g/card do more of the work.
Mactronix
Reply to mactronix
- 0 +
go into the nvidia console and turn off VSYNC. vsync makes your fps in games match that of your monitor which is defaulted to 60fps. with vsync on no matter what you do your fps will always be around there.
Reply to HYST3R
- 0 +
your cpu is definately not choking your 8800.
Reply to HYST3R
- 0 +
You said your motherboard has onboard graphics and you also had an ati graphics card before. Did you make sure that the old ATI drivers have completely been removed and that your onboard graphics has been disabled?
sidenote: how can mactronix make such an intelligent reply here yet ask basic questions on choosing which cpu to buy in another thread???
Reply to jeb1517
:lol: Dude i see where you are coming from but just because i have an understanding of how graphics cards work in relation to the cpu it dosent follow that i know how the cpu works.
Mactronix
Reply to mactronix
Yea that could be the kiddie right there.
Mactronix
Reply to mactronix
- 0 +
Mactronix
lol ok....for a second i thought it was like ur kid brother or sister or something posting under ur account...my bad. :kaola:
Message edited by jeb1517 on 07-26-2007 at 11:18:08 PM
Reply to jeb1517
- 0 +
im just guessing here as i dont own a 8800 and dont know its full capacity but have you tried knocking the AF down to say like 8, and see what the difference in fps is? 16x is pretty high and will cripple most cards im not sure if the 8800 will crank that out and maintain 100+ fps in those games. but definately check those old drivers and VSYNC.
Reply to HYST3R
Im no expert either but i think you may be confusing AF with AA as i know AA is a big hit but AF is nothing like as bad.
Mactronix
Reply to mactronix
This may be a dumb question but have you plugged in the 6-pin connector from your PSU to the video card. It just might not be getting enough juice.
Also, how long have you been using the PSU? It might just be time to get a new one...
Reply to Rage_3k_Moiz
Make sure you have the dual core optimizer from AMD. My question would be, hows your low fps? Disable onboard graphics in bios, go pcie only and reply here so we can help further.
------------------------------ I went drifting, thru the capitols of tin, where men cant walk and cant freely talk, and sons turn their fathers in
Reply to jaydeejohn
- 0 +
Sounds like drivers or PSU, 2 18amp rails on a random PSU doesn't qualify for a 8800 worthy PSU. If you removed drivers properly and it's still giving you issues, then the only thing I can think of is doing a clean install and considering on getting a better PSU.
------------------------------ Anxiously awaiting the Hydra 100 and the Hydra Engine...
www.lucidlogix.com
Reply to emp
- 0 +
I noticed people havent touched on this yet either. Using 4 sticks of memory is never good in AMD systems. It is always best to use 2 sticks for the best speeds. I'd switch your memory out for 2 one gig sticks instead of using those 4 512 sticks.
Reply to marike
There are 1006 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
