Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help Building Professional 2D System
Forum Homebuilt Systems : New System Build - Help Building Professional 2D System
I want to build a fast system good for multi-tasking. This is definitely not a gaming machine and will be mainly using it for surfing the net, listening to music, playing online poker (I run a lot of programs while playing and also am constantly storing information to a database). I want to be able to use two monitors at 1600 x 1200 res. Can someone help me build a good reasonably priced system ($1000)? Thanks.
Here is what I have so far:
https://secure.newegg.com/NewVersio [...] .asp?WishL istNumber=5347671&WishListTitle=PC+Build
I was also going to get the Q6600 as the processor. Does it all look good/work together (is this overkill for what I want to do with it?). I'm really a computer noob so any help would be greatly appreciated.
Sponsored Links
ur link is broke
post ur link again, and use www.tinyurl.com to make ur URL shorter :)
------------------------------ Best regards
Zidane_RM_5
Reply to zidane_rm_5
A Q6600 is way way overkill for your needs, hell even a modern dual core is too much I think. Try this instead (Will meet your needs just as good as your system would)
AMD Athlon 64 X2 4400+ Brisbane 2.3GHz 2 x 512KB L2 Cache Socket AM2 Processor - Retail
http://www.newegg.com/Product/Prod [...] 6819103776
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Prod [...] 6820231098
Leadtek WinFast PX7300GT TDH 128MB DDR3 Extreme GeForce 7300GT 128MB 128-bit GDDR3 PCI Express x16 Video Card - Retail
http://www.newegg.com/Product/Prod [...] 6814122008
(Nothing extreme about this card, except the name, but it will meet your needs with lower power requirements)
GIGABYTE GA-M61P-S3 Socket AM2 NVIDIA GeForce 6100 ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6813128034
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Prod [...] 6822148140
COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel, SECC ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Prod [...] 6811119068
FSP Group (Fortron Source) AX400-PN ATX12V 400W Power Supply 120/220 - 240v NEMKO, TUV, CSA, IEC, UL, CE - Retail
http://www.newegg.com/Product/Prod [...] 6817104953
About $495, add whatever you feel that it needs (Monitors, speakers, more HDDs, DVD Burner) but that will pretty much meet your needs the same way a Q6600 + SLI 8800GTX + 4GB of ram would. And to be honest even that system above is just overkill.
Message edited by emp on 07-26-2007 at 12:05:36 AM
------------------------------ Anxiously awaiting the Hydra 100 and the Hydra Engine...
www.lucidlogix.com
Reply to emp
You don't really *need* quadcore but you do want multi-cpu so I'd say go for a dual-core. THG seems to have removed the multi-tasking benchmarks from their charts but if memory severs me well the X2s were quite competitive there so don't shy away from AMD for a multi-tasking application. I would also suggest load balancing your activities across multiple HDs. SATA is a half-duplex protocol so it isn't well suited to multi-tasking and a single HD isn't a good match for multi-tasking either.
Message edited by flasher702 on 07-26-2007 at 12:52:04 AM
------------------------------ F@H
$$$ Looking to recruit a few good firmware developers, a mechanical engineer, and a senior hw+sw test technician in the Seattle area. PM me for details.
Reply to flasher702
There are 1290 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
