How do you use more than one hard drive on a system?
Last response: in Systems
- New build shuts off whenever I connect more than one hard drive - Forum
- Windows will not start properly with more than one hard drive installed - Forum
- Can i use more than one rail to power GPU? How? - Forum
- How do tell if one hard drive is faster than another? - Forum
- My hard drive properties say I've used more space than the properties of all my folders save to the drive. - Forum
- SolvedI got 2 hard drives and i dont know which one i should use for system and which one for my stuff(games etc.) Forum
- Solvedhow do i transfer specific files and operating system from one hard drive to another? Forum
- Plugging in more than one external hard drive freezes computer Forum
- is there more than one type of hard drive? Forum
- SolvedNoob-friendly tutorial on how to use this old hard drive on my new system? Forum
- how do i make my music files stay on my external hard drive, as i add more it seems to delete previous ones Forum
- SolvedHow to use two hard drives for one computer. Forum
- Hard Drive using 30GB more than I can account for Forum
- How do I connect more than one computer to the internet using one router in sepa Forum
- How to clone all from one hard drive to another except the operating system??? Forum
- SolvedWhat is the point of having more than one optical drive? Forum
- SolvedHow to replace dead RAID card after using one hard drive while waiting for replacement? (RAID-1) Forum
- Solvedhow to attach more than one fan to a header? Forum
- How to connect to one operating system to another installed in the same hard drive Forum
- SolvedHow to get good audio to more than one source Forum
- More resources
If the 2 drives are in raid 0 they will show up as one drive. Unless you really have four drives in 2 raid 0 arrays.
