Tom's Hardware Forums » CPU & Components » Power Supplies, PC Cases & Case Mods » Anyone have this Case & Power Supply Combo? Aurora 570 & Corsair 520W
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Anyone have this Case & Power Supply Combo? Aurora 570 & Corsair 520W
Profile: stranger
More Information
I'm looking to upgraded my case, and was wondering if anyone had the following combo:
GigaByte 3D Aurora 570
http://www.newegg.com/Product/Prod [...] 6811233013
and
Corsair 520W Power Supply
http://www.newegg.com/Product/Prod [...] MPSU-520HX
My concern is that the SATA power cables won't be long enough to reach from the Power Supply to the harddrive area and still have good cable management.
Any ideas?
Comments on the type of case are also appreciated.
Related Pr oduct
foz
Profile: member
More Information
The sata cable is 25 inches long to the second connector with 5 inches between the two. If you only use the second connector you should be fine. I you need more than two drives (you get 2 sata cables) you would need to buy some molex to sata adapters.
http://www.silentpcreview.com/files/images/corsair_psu/cables.jpg
Current Rig:
Gigabyte DS3 Rev.3, E4300 W/Ultra 120 Extreme(@3000mhz), 4GigsCorsairXMS2 CAS4 EVGA 8800GTS 320mb, WD 320&250 Gig, LiteOn DVD+/-RW, Corsair HX520 - Chenbro Net Server cube case - Acer 22inch WS
Add a reply
Google Ads
