This is my first build from scratch. I've been looking through some of the threads, and so I kind of know what I'm doing.
COOLER MASTER Centurion 5 CAC-T05-UB Black /Blue Aluminum Bezel , SECC Chassis ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119047
$49.99
GIGABYTE GA-P35-DS3R LGA 775 Intel P35 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128050
$129.99
SAPPHIRE 100196L Radeon X1950PRO 512MB GDDR3 PCI Express x16 HDCP Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102075
$189.99
APEVIA ATX-CW500WP4 ATX 500W Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817148027
$39.99
Intel Core 2 Duo E6600 Conroe 2.4GHz 4M shared L2 Cache LGA 775 Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115003
$222.90
Ki ngston HyperX 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134066
$138.49
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148140
$79.99
SAM SUNG Black 18X DVD+R 8X DVD+RW 8X DVD+R DL 18X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA DVD Burner With LightScribe Technology - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151141
$36.99
I'm pretty satisfied with the price range it's at now ~$900. I'm not planning on doing any overclocking, just yet, though I might consider it in a year or so. I'm going to be doing some moderate gaming on it, as well.
Do I need any cooling stuff, or will the stock fans do?
I'm probably also going to get a new monitor, keyboard, mouse, and speakers, so keep that in mind, too.
Any advice or suggestions? Have I overlooked anything? Thanks for your replies, I know you get a lot of threads like this one!
$49.99
$129.99
$189.99
$39.99
$222.90
$138.49
$79.99
$36.99
