Tom's Hardware > Forum > Homebuilt Systems > New System Build > Question about power supply - URGENT!
Forum Homebuilt Systems : New System Build - Question about power supply - URGENT!
The question is: I'm building a Q6600, Gigabyte DS3R, 2GB CORSAIR 800MHZ, Hard drive: WD 400GB, and an ATI x1950PRO / 8600 GTS. The power supply comes with an ARCTIC COOLING CASE (T5 Pro), and it has 500W and an efficiency of over 80%. Will this be enough for my sistem? Or should I get a more powerful source? I don't plan overclocking.
Sponsored Links
Firstly do your system spec in this psu calculator.
http://www.extreme.outervision.com/psucalculator.jsp
If it is a quality brand of psu then you could get away with it but to be on the safe side id suggest you get a decent well established psu. atleast 600-700w.
X
Reply to xstec
There are 987 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
