I recently bought 2x120mm ZM-F3 and 1x90mm ZM-F2 Zalman chassis fan to install into my case. One of the 120mm's will be used in the case (chassis fan), the other will be used on my heatsink (Thermalright Ultra-12) and the last 90mm fan will be used in the case (chassis fan).
Now, my question is, my current 120mm chassis fan is plugged into a 3-pin socket near the heatsink on my ASUS P5W Deluxe motherboard and is also plugged into one of the 4pinned thingies that comes out of the PSU, it's white and I have forgotten the name of it! The 90mm chassis fan was also plugged into a 4pin thing but not into a 3-pin socket on the motherboard and I have removed both of them, that's fine right? Now, for installing the fans, where would I plug in the 90mm chassis fan, the 120mm chassis fan and the 120mm heatsink fan?
Also, a quick question on my RAM if that would be OK:
I noticed that one of the heat spreaders has come loose off of one of the sides of a stick of 1GB OCZ PC2-6400 (special-ops edition), I'm guessing that it's not a problem, as only a little bit has come loose, but I just wanted to check nevertheless.
Thanks!
Thanks!
