Hello everybody.. hope some1 will help me
i have a problem with the following configuration
ASUS P5KC
Intel core 2 duo E6750
HighPoint RocketRAID 2320 controller
3 x WD Raptor 150gb
the problem is that the 3 disks are not recognized by the RAID controller BIOS.
i tried to plug another disk (not a raptor) and it's detected properly, and the raptor disks works couse connecting it directly to a motherboard sata port it works properly.
I dunno how to fix it
do you know if there is any issue with this controller combined with the WD raptor 150gb?
any suggestion?
thnx in advice for the help
ASUS P5KC
3 x WD Raptor 150gb
any suggestion?
