(I did post this under Windows XP general as well, because I wasn't sure where it should go, or if the fix is softare or hardware related)
I don't know what else to do. I cannot get XP pro 64 bit to install. Sometimes it doesn't even get to the copying files section. Sometimes it makes it almost 75% of the way.
I just built the system:
Antec 900
E6750
MSI p6n diamond
Sony Optiarce IDE DVD/CD drive (7170)
WD2500ys 250 gb hard drive
Crucial Ballistix 2 x 1GB ram pc 6400 (I have the other 2 to install too)
MSI 8800 gts 640 oc
OCZ 700w sli psu
I have an oem version of xp pro to install. I have many times tried to start over, repair, reformat, continue on the same partition, etc. I have yet to be successful and have now been at it for many hours.
Does anyone know why this won't finish the install? Most of the time it just stops making progress. Sometimes it gets my hopes up by copying many of the files and then stalls about halfway through.
I have checked the temperature through the BIOS. I have burned another copy of the CD (thinking the boot disk might be bad w/ the optical drive). I am at a loss for what to do.
If anyone has any idea, please (PLEASE!!!!) help me out.
Thanks so much
Antec 900
E6750
MSI p6n diamond
MSI 8800 gts 640 oc
OCZ 700w sli psu
Thanks so much
