Hi all,
I'm having a bit of trouble with a new build. I've been testing it's capabilities with Oblivion, and the system will power down, without warning, as if someone pulled the plug. It only seems to happen when playing Oblivion, but I have no other real intensive games.
I've noticed that if I have anti aliasing turned on, it happens nearly immediately when I go outside within the game.
Without AA, it runs the game fine for a few hours, but eventually powers offf.
At first I thought it may have been an overheating problem, but my CoreTemp readings all seem to be under 55C.
Then I thought it may be power, so I unplugged the cd drive, and took the side of the case off (which had 2 LED fans, system still runs under 55 without them.)
I've flashed the bios, and that didnt seem to do anything.
I never assumed that the video card would be able to kill the power, but I've been wrong before.
Would you say this is a power, mobo, or video issue?
System:
Power - Rosewill 500W http://www.newegg.com/Product/Product.aspx?Item=N82E16817182044
Motherboard - MSI P6N Platinum http://www.newegg.com/product/product.asp?item=N82E16813130081
Video card - EVGA 8800GTX http://www.newegg.com/product/product.asp?item=N82E16814130072
RAM - Patriot DDR2 2x1gig http://www.newegg.com/Product/Product.asp?Item=N82E16820220144
Proc - Intel E6600 http://www.newegg.com/Product/Product.asp?Item=N82E16819115003
System:
