I am attempting my first ever build. Exciting!! After doing some research on the web I have decided on the major components I will use. Was hoping to have peoples opinions off here if I am on the right track. Basically I want the machine to be able to play most games at a high level also want to use it for graphic design.
Here are the components I plan to use.
Motherboard:
- Asus M2N-SLI Deluxe
CPU:
- AMD Athlon 64 X2 Dual-Core 3800+ Socket AM2 CPU
GPU
- 8800GTS 640MB
Ram
-2G DDR
HDD
- 200GB Sata
PSU
-450W
Motherboard:
CPU:
GPU
- 8800GTS 640MB
Ram
-2G DDR
HDD
- 200GB Sata
PSU
-450W
