nitro2345
Hi there! I hope someone can help me out with this one. It turns out that I have one file(.avi) in my computer that I can't delete . It actually took me a lot of time to transfer it for its original location to the recycle bin, and once there it can't be deleted =( and wherever I store the file, makes that location consume a looot of memory, making the CPU usage up to the 100%,making my computer do produce noise... what can I do???, I have tried using the antivirus but no result, thanks
Boot into safe mode, and try to delete the file there.
You can also right click on the trash can, click properties, and change the amount of space the trash can will hold. You can also set it to skip the trash can, and just immediately delete items.
nitro2345
thanks for ur advice I will try that.
